Old 04-06-2009, 02:40 PM   #1
Send a message via AIM to big_dog1893
Default Engine Problems
I Recently acquired a Novarossi S21 with a O'Donnell's cooling had.. i ran it for a little bit now For the new season id like to send the piston and sleeve off to Os-Rocket for a pinch. (now is where the problem lies)
Almost all of the engines i have worked on have HEX head screws that hold the cooling head on. The Novarossi for some reason has Flat-head screws holding the head on the block. They seem to be in their so good that i cannot get them out.. I have twisted two flat head screwdrivers. trying to get them out they just will not budge.
Is their anyway possiable getting these things out so i can send the sleeve and piston off and have a good engine by time the dirt season comes around??
any suggestions would be greatly appreciated.
Thanks in advance..
For Bashers, By Bashers - http://www.BigSquidRC.com
Home Track.
http://tri-statehobbies.com/
big_dog1893 is offline   Reply With Quote
Old 04-06-2009, 02:45 PM   #2
Trader Rating: 16 (94%+)
heat it up and use a good quality screwdriver
imjammin is offline   Reply With Quote
Old 04-06-2009, 03:39 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
http://www.amainhobbies.com/product_...oducts_id/8382
Is what I use.
Here is a cheaper version
http://www.amainhobbies.com/product_...ducts_id/33341
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-06-2009, 03:55 PM   #4
guambomb's Avatar
yup use a propane torch and a good screw driver
guambomb is offline   Reply With Quote
Old 04-06-2009, 03:55 PM   #5
shesha's Avatar
Send a message via MSN to shesha
heat the head up and use a screwdriver that fits perfectly, you do not want a screw driver that plays in the - slot you want a snug fit and put pressure down on the head when you are unscrewing.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 04-06-2009, 05:24 PM   #6
All screws are out and the piston and sleeve will be going out for its pinch. tomorrow.. one more question though
does anyone know the factory needle settings for the Novarossi s21 p5x
Home Track.
Old 04-06-2009, 06:05 PM   #7
madmaxx's Avatar
no chance of getting a screwdriver back on it? IF you can; try to put some heat on the BLOCK where the stuck screw is (the screw thread's into the block NOT the head) after you warm up the block try to tap the head of the screwdriver handle while turning it to give it a bit of a helping hand!
if you ever used an impact driver you will know what i'm reffering to
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 04-06-2009, 07:25 PM   #8
SPEED37's Avatar
Carb settings........
http://www.novarossi.com/content_uk/...y-engines.html
JAMMIN X2 CRT/HOUSTON/NOVAROSSI P5XS/OFNA-053
JAMMIN X2 CR/NOVAROSSI
SPEKTRUM/DX3S
BCG INDUSTRIES= Absolutely the best paint on the planet.
TEAM TERRIBLES
SPEED37 is offline   Reply With Quote
Old 04-06-2009, 07:28 PM   #9
SPEED37's Avatar
oops... forgot the s21
http://www.novarossi.com/content_uk/...r/s21p3xst.htm
Carb settings on the left.
SPEKTRUM/DX3S
TEAM TERRIBLES
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 04:32 PM
JP engines jasoncsc Onroad Nitro Engine Zone 1160 05-10-2017 07:19 AM
Trinity EXTECH .21 Fierle03 Offroad Nitro Engine Forum 2130 06-09-2011 07:01 AM
Idleing problems usa98030 Nitro Off-Road 32 12-13-2008 12:37 PM
axe rossi x1 evolution engines thread zixxer Nitro Off-Road 31 11-23-2008 07:46 AM
What Fuel? diablo05 Singapore R/C Racers 15 03-20-2007 07:28 AM
Collari XS12RR nitroaddict Nitro On-Road 10 11-13-2003 06:00 AM
