Old 04-06-2009, 02:11 PM   #1
Default TRAXXAS SLAYER
has anyone used the conversion kit to run 17mm wheels and does it make it handle any better mine is crazy on a dirt oval
FIELDS is offline   Reply With Quote
Old 04-06-2009, 05:15 PM   #2
madmaxx's Avatar
are you asking about the hexxe's? if so the only real benefit you will get from them on that truck is you wont spin the hexxe's in the rim's as easily or at all.
i'm not 100% shure but i think you are limited to the same size wheel's on those truck's?
your handling issues is not caused by the size of the wheel hex but rather the setup of the truck, try googling for a slayer setup sheet or check out traxxas.com and see if they have some info posted on how to set up the slayer for dirt oval....
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 04-06-2009, 06:24 PM   #3
Ridley's Avatar
The hexes allow you to run buggy wheels and tires......It should be a huge advantage but I couldn't tell you for sure.
Ridley is offline   Reply With Quote
Old 04-07-2009, 09:35 AM   #4
madmaxx's Avatar
^^ there ya go! learn somethin' new everyday
Old 04-07-2009, 01:42 PM   #5
yes you can i run Ofna 17mm hex adapters got off ebay at Hopmeup.comi run pro line 1/8 buggy wheels with pro line badlands they hook up good on dirt oval and on traxxas.com home page to the right is a setup for the slayer everything you need to know
laser_cart is offline   Reply With Quote
Old 04-07-2009, 03:40 PM   #6
thanks for the info guys
Old 04-08-2009, 07:21 PM   #7
infernus1986's Avatar
ive been looking in to this for a while and the way to go seems to be either 1/8th scale buggy wheels or 1/2 in offset 2.2 mt wheels either way ur gonna need 17mm adapters.
personally im looking at 1/2 offset rpm revolvers with Panther Komono Dragon LP tires.
other options to keep the stock wheel look are the proline switch beadlocks which ive heard bad things about tires pulling off
Asssociated SC8 aka KMC wheels are suposed to fit with 17mm adapters and there dirt cheep for 63 bucks for 4 mounted tires and rims from tower
infernus1986 is offline   Reply With Quote
Traxxas Slayer Thread Drift_Buggy Nitro Off-Road 116 01-25-2014 04:31 PM
Traxxas Slayer Roller- Brand new $300 shipped RCNUT R/C Items: For Sale/Trade 31 02-17-2009 08:22 PM
