Old 04-06-2009, 05:36 AM   #1
elkman's Avatar
Default losi Mach 427 seized!
New LOSI 8ight truggy RTR, I am not new to RC and not new to nitro. I broke in the engine to specs, and only ran about 2 1/2 gallons through it total. Always do proper after runs and have never let the engine get above 230. I was running this weekend on a nice 72 day here in Oregon (rare for this time of year) and when I was making a pass the engine died for no reason. When I tried to start it with the spin start, the car jumped with the starter torque. The engine was seized. I pulled the glow plug and tried it again thinking it may have hydraulically locked and same thing. I pulled the exhaust pipe from the engine and could see small metal pieces!. I was able to push the piston down with a screwdriver and can make the piston go up by turning the flywheel in the run direction but it gets stuck at TDC. I think the bottom end let loose. Maybe the crankshaft? I am going to call Team Losi and ask them what they can do for me. Has this ever happened to anyone here on a 427 rtr engine with very low hours? Do you think Losi will warranty the engine or give me a break on a new engine? if they dont, can you recommend a replacement engine for under $200 bucks. ( I saw that a replacement 427 was $139.00 +the ride.)
Any help would be appreciated because run season is fast approaching and I don't want to be a spectator. My son has the same exact car with about the same anount of run time and his is acting fine.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 04-06-2009, 08:09 AM   #2
rc-mike's Avatar
If I had to guess I'd say the bottom of the connecting rod broke but there is no way to know unless you take the backplate off. If it was me I'd probably talk to Horizon Hobby since they distribute Losi stuff now and from what I have read they have been taking care of problems better than calling Losi direct.
rc-mike is offline   Reply With Quote
Old 04-06-2009, 08:15 AM   #3
elkman's Avatar
Default I called Horizon
I called them this morning after I got to work. They want me to send the motor to them and they will take a look at it. I hope they send a new one back to me! I wondered if this was a one-off failure or has anyone experienced the same thing (bad design)
****RUSH****
Old 04-06-2009, 08:22 AM   #4
Chill_Will's Avatar
Trader Rating: 32 (100%+)
My 427 done the same thing Sunday. It race great Saturday but Sunday I put it on the starter box and it started up and went pop. I knew what it was. It had less than 2 gallons in it. I'm going to replace the rod and see what happens.
A-Train racing (Woooooo Wooooo!!)
Chill_Will is offline   Reply With Quote
Old 04-06-2009, 10:07 AM   #5
madmaxx's Avatar
i love guessing! how 'bout you?
i just re-built one of these that had prolly between 4-5 gallon's on it and the rod was still in great shape as well as the pinch! only problem with it was that some how the wrist pin retaing clip popped out of the piston and scored the sleeve!
no biggie as everything else is still good to go! slapped a new P/S in there along with the old rod just waiting on a couple thing's so i can hot rod it and a starter wheel for my starter box to start break-in
i got P/S/R for like $45! can't beat that!
the new rod will go in after break in is complete
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 04-06-2009, 10:25 AM   #6
Akhor's Avatar
They are really great with product support. I'm sure they will make it right for you.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 04-06-2009, 11:14 AM   #7
elkman's Avatar
Default That's good to hear
I will keep you guys informed.
****RUSH****
Old 04-23-2009, 05:18 AM   #8
elkman's Avatar
Default Replaced
Got my new engine yesterday!. The note in the box said that my connecting rod was broken and had done other internal damage. They said it was not cost effective to repair so they sent me a brand new engine!.Thanks Horizon Hobby.
****RUSH****
Old 04-23-2009, 06:02 AM   #9
the con rods in these are a weak point, will look on ebay or LHS to buy a new one, once you break it in, change to the new one and it should last a while
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
WHAT DO YOU THINK ABOUT THE LOSI MACH 427 pimptasticksilk Nitro Off-Road 31 03-23-2014 05:34 PM
