Old 04-05-2009, 05:01 PM   #1
nitrospeeddemon's Avatar
Default Break in problem
Hi, Im breaking in a new O.S. 21 VG and everytime I remove the glow starter it stalls out. I tried running it with it on and it goes no problem. Please tell me what I should do to fix this. Thanks.
Jammin X1-CR
O.S. 21 VG
Airtronics MX-3
nitrospeeddemon is offline   Reply With Quote
Old 04-05-2009, 05:05 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Either the mixture & idle settings are way off, the glowplug is no good, or the fuel your using is garbage.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-05-2009, 09:38 PM   #3
richen bottom end
tom slick 50 is offline   Reply With Quote
Old 04-05-2009, 10:04 PM   #4
I ould say try leaning the bottomend a but and or getting a hotter glow plug. not sure if the hotter glow plug theory will work I just thought it maid sense so I would post it.
rgrassey@me.com is offline   Reply With Quote
Old 04-05-2009, 10:09 PM   #5
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by rgrassey@me.com View Post
I ould say try leaning the bottomend a.
Originally Posted by tom slick 50 View Post
richen bottom end
Well, he should have a clear idea of what to do now
cpaurl
rallyebmx is offline   Reply With Quote
Old 04-05-2009, 10:22 PM   #6
TTR:EB4's Avatar
firstly i would try a new plug, maybe a hotter one too
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 04-05-2009, 10:30 PM   #7
r1harper's Avatar
Trader Rating: 24 (100%+)
too rich on bottom...the heat from the glow igniter is what is keeping it running.
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 04-05-2009, 10:35 PM   #8
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 04-06-2009, 01:59 AM   #9
This give's me cold chills.
The Working Man is offline   Reply With Quote
Old 04-06-2009, 02:35 AM   #10
cluffy1's Avatar
Smile
i had this problem as well, it is because the glow plug needs to have platinum on it to allow for the fuel to egnite, the methanol in the fuel reactes with the platinum on the glow plug and allows the glow plug to keep inniting the fuel. just replace it with a new one and your are golden.
cluffy1 is offline   Reply With Quote
Old 04-06-2009, 03:12 AM   #11
losi_racer's Avatar
Trader Rating: 25 (100%+)
he has the smartest sounding answer so go with him HA HA HA jk.... but seriously idk about the whole platinum thing or not but the plug is bad.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 04-06-2009, 03:45 AM   #12
jamiekerr14's Avatar
What plug you using, you should be ONLY using the O.S. P3.. you should only really run that in V-Specs.. I do and that is what they recommend..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 04-06-2009, 04:26 AM   #13
Change plug, ok.
9 of 10, the factory setting is to rich.
You can tell if fuel is running from your stinger (pipe).
Preheat and many problems will be gone, a good plug will terminate many other issues, a fresh glow starter will finish of the other problems.
If this doesent work, and you have no indications the engine is running lean; lean the sucker
MBX-6
Caster MK2 / N21BF / P5XLT H.E.S.
casevac is offline   Reply With Quote
Old 04-06-2009, 07:21 AM   #14
deweyharding's Avatar
Trader Rating: 39 (100%+)
richen the bottom and a hotter glow plug will help the motor idle
deweyharding is offline   Reply With Quote
Old 04-06-2009, 10:02 AM   #15
Default re
why not leave the igniter on it for the first tank?get some heat and time thru the motor wont hurt but you should never adjust the bottom end on a motor until the the high tneedle has been set proper period turn the idle screw in if needed may help blip the throttle and clear it out before you remove the igniter
toofless is offline   Reply With Quote
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Alex Racing Barracuda R2 & R3 SpeedTech Electric On-Road 14383 08-21-2014 06:06 PM
Crazy OS V-Spec Break In Methods? Don Duct Nitro Off-Road 22 05-12-2008 06:17 AM
SoCal Raceway Neil Rabara Racing Forum 11505 01-13-2008 01:20 PM
Another Break-in Question Thread jcrouse Nitro On-Road 7 08-01-2003 10:19 AM
Help to tune a Collari X12 Romeo156 Nitro On-Road 16 05-08-2003 01:30 AM
