Old 04-05-2009, 06:11 PM   #16
xDaRReLLx87's Avatar
wow, I just tried some pledge and that stuff works quite well.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 04-05-2009, 06:17 PM   #17
imaxx21's Avatar
Send a message via AIM to imaxx21
clean and shine Pledge is the best (orange can)
also if you are into motorcross try some SC1 on your car, stuff is awesome
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-05-2009, 06:32 PM   #18
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1 I use the orange stuff. It works very well and smells great.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-05-2009, 06:42 PM   #19
I got that too, I usually use it to clean my guitar fret board.
Old 04-05-2009, 07:19 PM   #20
n10cities's Avatar
Default Lacquer thinner???
Has anyone tried Lacquer Thinner to clean bearings and diff parts? Definitely cannot use on plastics, but I found it worked very well when I used to run electric (run nitro now) It stinks to high heaven, so you have to store in a sealed container.......any thoughts?
Your arrogance blinds you.....
Losi - Spektrum - Byron's Fuel - Airtronics
Robbie
GSHobby.com
n10cities is offline   Reply With Quote
Old 04-05-2009, 08:17 PM   #21
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Lacquer thinner works very well. Just make sure you get all the solvent out. Any solvent left behind will dilute any new grease applied to bearings after cleaning.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 04-05-2009, 08:28 PM   #22
imaxx21's Avatar
naptha works better
-Crash
Old 04-06-2009, 02:20 AM   #23
cluffy1's Avatar
Unhappy
when i clean my D8 i just tear it down take the bearings out, spray everything with degreaser, and hose it down and allow it to dry overnight. is there anything wrong with that. (do the same for all parts of the car).
cluffy1 is offline   Reply With Quote
Old 04-06-2009, 03:16 AM   #24
losi_racer's Avatar
Trader Rating: 25 (100%+)
idk if it has water in it or not. if no then your going to have a rust bucket soon. i just spray everything off with air comp
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 04-06-2009, 08:12 AM   #25
perhaps, imaxx21 should do a write up on a "How to on cleaning your R/C racecar"
Old 04-06-2009, 12:58 PM   #26
shesha's Avatar
Send a message via MSN to shesha
After electronics off and engine, hot water clean of, then simple green then let sit for 5 minutes, then wash of with hot water then air dry everything with air compressor.
Electronics I just use a damn cloth with some simple green and clean of with brush and wipe down.
Engine denatured alcohol wash down from the outside everything sealed, then blow out with compressor.
Car is clean All this is done in 30 minutes at the most.
Hard to reach areas use the cleaning gum so it saves you time otherwise I just use air compressor which is set on a very high pressure to blow things in out in tight areas.
In all honesty the air compressor is the key.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 04-06-2009, 01:34 PM   #27
cary's Avatar
Trader Rating: 67 (100%+)
what is cleaning gum to day is the frist i have heard of it saw it
on neo buggy and now hear how do you use it where do you
get it
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-06-2009, 01:43 PM   #28
rc-mike's Avatar
I thought it was something else misspelled actually.
rc-mike is offline   Reply With Quote
Old 04-06-2009, 02:37 PM   #29
Mack_Mechanic's Avatar
Cleaning gum.http://www.xceedrc.com/product/103232
Steve Arms
www.rcracebarn.net
There is no such thing as too much motor....just not enough driver!
Mack_Mechanic is offline   Reply With Quote
Old 04-06-2009, 03:17 PM   #30
shesha's Avatar
It's just a gum like play doh for kids that squeezes into tight areas and picks up dirt oil grit etc, the good thing about it is you just roll it in your hand and it cleans itself, it has a life expectancy usage wise, but it will be a while before it becomes useless, lets just say you get your monies worth.
Actually the cleaning gum is mainly used by onroad drivers, however does not stop you from using it on offroad just try to avoid the dirt by cleaning as much as you can.
1/8 sportwerk buggy, 1/10 Rc10gt, Kyosho mini-Z All for sale guss2009 R/C Items: For Sale/Trade 15 08-22-2009 09:41 PM
Kyosho V-One RRR WCE & Engine/Pipe MRX4-R03 R/C Items: For Sale/Trade 8 05-07-2007 11:06 PM
Jammin CRT McCleary.11 R/C Items: For Sale/Trade 9 03-24-2006 08:37 PM
Simple Green Safe on Plastic? AE Racer Electric Off-Road 18 06-23-2004 11:14 AM
Some Newbie Questions on Nitro R/C's! Shimzuka Rookie Zone 17 11-07-2003 11:48 PM
