Old 04-06-2009, 03:53 PM   #16
shesha's Avatar
Send a message via MSN to shesha
check your shim you should be in the .6 range and if your running 30% you should be using cold plug, the restrictor plays a good role in the fuel milage and so does the pipe, you may want to consider retunning the engine, temp is not eh key to the tune but will give you an idea if your still on the rich side if your not familiar with the engines performance, I just go by sound and peformance dont go to lean but in general milage will increase if your not running rich, the number of cars i have seen on the local tracks according to the racer saying the performance is good, in my perspective they are abotu 3/4 out on the needle to race tune.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 04-06-2009, 08:27 PM   #17
Trader Rating: 52 (100%+)
Originally Posted by mbrienzo View Post
Mo,
did you pit at 10 minutes also? Did it have enough bottom or just controllable. Give me some info as I am trying to find an alternative to the Nova pipes.
actually tons of bottom even with my servo slowed to 85. i pitted at 8 to get away from a lapped throttle jockey then came in again at 19 then ran the main out. if you want to try it lemme know you can borrow it if you want. i also want to try the 2060 on it this weekend.
MO
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 04-07-2009, 08:01 AM   #18
MO
I am going to try the 2050 and see what that does. I would like to know how the 2060 does and may want to try the Losi pipe.
Panther Tires, Novarossi, Fusion Motorsports, Fastraxx Hobbies, Answer-RC USA
mbrienzo is offline   Reply With Quote
Old 04-07-2009, 08:13 AM   #19
markr04's Avatar
Another vote for the RE11. I get 10+ minutes out of my Go 7-port .21 in my truggy. lol.
Xray 808 2010 Spec - O.S. V-Spec Speed - Airtronics M11-DSSS
Losi 8ight-T 2.0 - RB Killer 9 - Airtronics M11-FHSS-2
Losi XXX-CR - Tekin RS / Novak Ballistic 13.5 - Airtronics M11-FHSS-2
markr04 is offline   Reply With Quote
Old 04-07-2009, 03:39 PM   #20
pitpop's Avatar
Fuel mileage is a complex equation, but I can narrow it down to the 3 most important factors (IMO ).
1. Conservative crank and port timing with a docile sleeve configuration will provide better fuel economy.
2. Driver. The driver needs to be calculated and not excited. A smooth finger will gain mileage.
3. Tune. You can't be fat...
Nitro and oil content play a factor, but you can go the distance with most of the low oil content 30% fuels on the market these days, if you have the above 3 items figured out.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 04-07-2009, 04:20 PM   #21
houston's Avatar
Trader Rating: 91 (100%+)
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 04-07-2009, 04:29 PM   #22
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by jrwoodchuck View Post
rfleck and i race together and he was the first to make the 10min heat with no pit stops. i did give him a hard time about the 4 feet of fuel line in his car, but had to shut up when it teched dead on at 125cc. but both of us can make the 10 minute heats. i use the stock 8mm restrictor and can get full throttel if i need it, i'm not sure what restrictor ron is using
He's using a 7, and has his endpoint limited... and using the RE11 pipe.
I WAS getting 12 on the old layout with 7mm restrictor, Dynamite 053 pipe... but can barely make 9 on the "full wood" track layout they have now at Indy. (Ron and I run VSPECS, forgot what Doug runs, but I think he has something similar...)
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 04-07-2009, 04:37 PM   #23
jrwoodchuck's Avatar
i guess the question should be asked if you are running a buggy or a truggy when it comes to how long it will run. it is deceving when guys say they can get 12 minutes without letting you know it's in a truggy that has a 25cc larger tank then us buggy users.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 04-07-2009, 04:46 PM   #24
Trader Rating: 24 (100%+)
If you get the correct pipe either the Nova pipe recommended for it or something close that will be a huge help. I was at one of the local tracks in vegas helping Drake while we tuned and tested runtime on that engine. His was fairly new at maybe 1/2-3/4 gallon and with a 7mm, temping about 230ish and he was going over 10 minutes.
With his plus 4's he was doing 12 and on the silverstate track he was getting about 10:45
So it's just a matter of a proper tune, the correct pipe, and decent fuel(some get more mileage than others).
So try either the nova pipe, what black said, or the new losi pipe..
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 04-07-2009, 04:47 PM   #25
Jaz240's Avatar
Doug (Chuckers)
two point oh, tripple ex see are, em eleven
that's so painful to read
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 04-07-2009, 04:49 PM   #26
Originally Posted by Jaz240 View Post
Doug (Chuckers)
you must have gone to public school.
Doug
TLR 22/M-11
Old 04-07-2009, 04:52 PM   #27
Jaz240's Avatar
No I'm blind! But I could almost swear at the front part there where it says XRAY 808..it almost looks like two point oh
Old 04-07-2009, 05:02 PM   #28
sorry, i couldn't swallow the xray punch any longer. (jonestown referance)
Doug
TLR 22/M-11
Old 04-07-2009, 05:04 PM   #29
bustedpiecesrc's Avatar
Trader Rating: 51 (100%+)
Send a message via Yahoo to bustedpiecesrc
ok guys, im running a RB WS7 2 in my buggy with 30% and a mccoy59 plug and i was lucky getting 6 minutes out of it at 260 temp, but i was running a ofna pipe that i couldnt tell what it was, what pipe should i run with the RB?
EVERYTHING IS FOR SALE
Associated FT NTC3 with Picco/ dirt oval Latemodel
Associated FT TC4 Latemodel MMP fantom 10.5
Mugen MBX6 nova +4
bustedpiecesrc is offline   Reply With Quote
Old 04-07-2009, 05:42 PM   #30
same bro....the losi re11. 10 plus with that motor as well. on an s-7 with a ws-7 piston sleeve and conrod.
MO
Team Losi
fast for an old guy
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Run time out of Sirio, HELP?? CHogle Nitro Off-Road 18 08-12-2009 10:02 AM
1/8th scale Fuel Mileage Thread Scootersisters Nitro Off-Road 8 10-07-2007 06:27 PM
Fuel Mileage blues? rltanner Nitro Off-Road 33 09-25-2007 12:36 AM
Poor fuel mileage Jasonsuper50 Electric Off-Road 17 06-28-2006 07:42 AM
