Old 04-05-2009, 04:53 AM   #1
Exclamation Help tuning my car up.............
Couple problems i need sorting if possible with your help...
1.Full tank of fuel lasts literally 1 minute or 2 tops. Although its not noticably coming out of the exuast or leaking anywhere!
2.doesnt brake at all.
Im guessing i need to fine tune the engine up properly. Instructions taken from manufactuar homepage...
Main needle valve:
2-1/2 to 3 turns counter clockwise, out from the closed position.
Idle adjustment screw:
should be set so that the throttle is open approximately 1mm
(0.039inch) from the "just-closed" position. (does this mean i close the screw clockwise till it stops then open it by 1mm??)
The engine is a TEAM INFINITY .18 im using tornado 16% fuel.
Helpppp plsss!!
j4gg4 is offline   Reply With Quote
Old 04-05-2009, 09:54 AM   #2
savage.25's Avatar
Send a message via MSN to savage.25
ya you'll want to play with the tuning a bit.. sounds like it might be too rich. set the high and low speed needle to factory (screw the needle all the way in then 1 1/2 turns out.
brakes.. try adjusting it.
savage.25 is offline   Reply With Quote
Old 04-05-2009, 11:21 AM   #3
savage.25's Avatar
i was thinking about it and if adjusting the brakes doesnt work then take a look at the actual brake disk and if its not too bad then im not sure what else to do, but if its worn enough then replace it.
Old 04-05-2009, 11:38 AM   #4
xDaRReLLx87's Avatar
I would try adjusting the brake linkages as he probably doesn't have them set strong enough
May I ask what car your driving? Btw 16% nitro fuel is pretty weak.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Xray NT1 aantonis Nitro On-Road 7512 08-14-2017 02:55 PM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 08:13 PM
Mamba max viable for racing? phixd Electric Off-Road 48 10-19-2008 07:23 PM
Help with a AXE mamba .21 grivero Nitro Off-Road 17 05-11-2008 02:50 AM
Help me to choose! Please!!! armaco Electric Off-Road 7 02-03-2005 07:55 PM
After reving, High idle....Whats wrong? Rapid Roy Onroad Nitro Engine Zone 7 12-21-2004 12:03 PM
