Engine piston pitting?
Is the top of the piston supposed to turn a brownish black after its broken in? or is it supposed to stay shiny silver?
Also, what does pitting look like? I heard this happens from to much compression. thanks |
Originally Posted by team2zon
(Post 5641625)
Pitting is not normal, carbon colored coating is normal as well.
Pitting is little pin holes starting to develop in the piston . This can happen from too much compression , not enough shims or longer glow plug .
if the top of the piston looks like its been sandblasted ...its been run to lean....carbon build up is always normal
I have heard that running too hot of a plug can also do that.
Originally Posted by Dalepad
(Post 5642565)
Pitting is like pinging in a 1:1 engine. It's mostly from pre-detonation of the fuel/air mix. This could happen when the engine is overheated, using a hot plug (similar to advancing the timing), running too lean or not shimmed properly.
Another effect of pre-detonation is excessive wear on the conrod and shaft journal bushings. |
Originally Posted by Briguy
(Post 5642454)
Pitting is surface deformation on the piston head and underneath the button head. They become sand blasted due to overheating, perhaps due too high percentage on nitro % or running too lean. I've got this pitting problem 3 times...... To reduce pitting : polish the piston head and button head until they become so shiny. I find this trick work very well to minimize pitting. I use dremel and round wool type tip, especially meant for polishing jewerly. Don't polish inside the sleeve or inside the engine wall where the sleeve is seated. |
Originally Posted by asw7576
(Post 5642963)
:lol::lol:
Pitting is surface deformation on the piston head and underneath the button head. They become sand blasted due to overheating, perhaps due too high percentage on nitro % or running too lean. I've got this pitting problem 3 times...... To reduce pitting : polish the piston head and button head until they become so shiny. I find this trick work very well to minimize pitting. I use dremel and round wool type tip, especially meant for polishing jewerly. Don't polish inside the sleeve or inside the engine wall where the sleeve is seated. He asked what it looks like . Not what it is , what it looks like . So not sure why you are laughing at my post . |
(Post 5643181)
:confused::confused:
He asked what it looks like . Not what it is , what it looks like . So not sure why you are laughing at my post . Look like having a carbon build up is normal. Look like it has been sand blasted, it's not normal. |
Ya , I know . Where did I say pitting is normal ?
(Post 5642963)
:lol::lol:
(Post 5642963)
:lol::lol:
(Post 5643635)
Instead of polishing you should fix the problem why it is happening . That is just putting a band aid on it instead of taking care of it .
