Old 04-04-2009, 09:53 PM   #1
Default Noises coming when I let off my throttle?
Just thought I'd ask while im bored. When I was driving my losi 8ight 1.0 today I notice right when I let off the throttle I heard some kind of noise. Sounded like the gears being to tight but I thought my clutch bell mesh was good but idk. Could it be from the diffs if there isnt enough fluid in it? Also every time I hit the breaks I heard kind of the same sound but it was just a quick sound. It was like the gears were hitting eachother. Sounded like a clink? Is my mesh to tight?
rgrassey@me.com is offline   Reply With Quote
Old 04-04-2009, 10:02 PM   #2
xDaRReLLx87's Avatar
Do you have to much drag brake dialed into the car? Thatss all I can really gather from your information. What type of sound did it make? Crunchy?
Is your Diff loose? IT can make quick grinding sounds if you have it a little to loose.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 04-04-2009, 10:06 PM   #3
Have you ever considered a "Ask rgrassey@me.com 8ight 1.0 questions!?"
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 04-04-2009, 10:06 PM   #4
yes a bit crunch, im not sure how to know if my diff is loose. Also what do you mean by drag brake?
Old 04-04-2009, 10:11 PM   #5
lowblktaco's Avatar
Trader Rating: 21 (100%+)
I had a similar noise in my 1.0, but it was when I used brake. Turned out to be the rear diff/pinion was misaligned just a tad. I simply took it apart, cleaned everything up, set the pinion/diff gear mesh and put it back together.
Oh, also check for small rocks in the drivetrain. They can be culprits as well.
lowblktaco is offline   Reply With Quote
Old 04-04-2009, 10:13 PM   #6
Well, typically on most cars you can insert a flat head screwdriver into one of the sides of the diff, you can look in the light to see which side of the diff has the flat head slot. You generally tighten it to the right to tighten your diff. On your car, there are brakes and drag brake. The Drag brakes are applied when you let off the throttle, which slows the car down and also effects the flight characteristics of your buggy. You can adjust both throws with a simple hex head tool. I haven't fooled with a 1.0 in quite a while, but I'd look into your manual for the "tips from the team" section and see what they suggest.
+1, dirt can definitely be your enemy.
Old 04-04-2009, 10:19 PM   #7
The sound when braking only happens when I actually hit my brakes. It sounds like the gears are just stopping and making a sound whn my car is eally still moving
Old 04-04-2009, 11:10 PM   #8
Usually you get gear noise from to tight gear mesh, to loose gear mesh, or from worn gears. Also it usually between the bell and spur. Gear misalignment oand the clutch can cause noise also.
John Schafer is offline   Reply With Quote
Old 04-05-2009, 01:04 AM   #9
Gliptal's Avatar
Are you still running the plastic bearing inserts for the rear diff? The stock plastic ones get sloppy and ring and pinion will start to slip. Not sure if that's what your describing, it will sound like a popping sound at first, you will hear it while braking or accelerating through a rough section.
Also, I've never heard of anyone using drag break in 1/8 scale but I guess you could.
Gliptal is offline   Reply With Quote
Old 04-05-2009, 01:26 AM   #10
karnao's Avatar
+1 i had the same problem.
new plastic ones will fix it
aluminum ones will last a lot longer.
karnao is offline   Reply With Quote
Old 04-05-2009, 03:30 AM   #11
Trader Rating: 36 (100%+)
If you're gonna be up @ Wolcott today, I can take a look at things for ya. From what I'm seeing, it doesn't sound like enough people will be there to race as most are either going to RCM or Vineland in NJ. But I am sure that Les will have open practice at the very least.
NitroOB4You is offline   Reply With Quote
Old 04-05-2009, 06:01 AM   #12
Mlbracing's Avatar
Did you recently change the clutch or spur?
When I my center diff to the smart diff I heard a noise and it was just a worn clutch to the new spur
it could be that
~ Team Associated ~ Jconcepts ~ Byrons Fuel ~
Thanks to my dad and everyone who helps us out!
Mlbracing is offline   Reply With Quote
Old 04-05-2009, 06:37 AM   #13
yes I just got a new clutch bell. I will try to re-do my mesh and see what hapens. Also What is the bearing insert?
Old 04-05-2009, 06:42 AM   #14
Actuall I just looked at the exploded view and my bearing inserts were aluminum. I think it may just have been to tight f a mesh. but I just wanted to check
Old 04-05-2009, 07:01 AM   #15
xlgraphicspro's Avatar
This sounds like advice for an electric buggy! You can't tighten a 1/8th buggy diff from the outside.
Aside from that, it sounds like a gear mesh issue, it could also lead to the premature death of your clutch bearings. Your clutch bearings would definatly make the noise your talking about when they are almost ready to blow, if they aren't already blown.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
