Old 04-04-2009, 08:26 PM   #16
sounds like this new mount is the right thing!! I am going to send the cash right now.
rgrassey@me.com is offline   Reply With Quote
Old 04-04-2009, 08:29 PM   #17
bustedpiecesrc's Avatar
Trader Rating: 51 (100%+)
Send a message via Yahoo to bustedpiecesrc
no problem... you wont be dissapointed with A.C.E. parts
EVERYTHING IS FOR SALE
Associated FT NTC3 with Picco/ dirt oval Latemodel
Associated FT TC4 Latemodel MMP fantom 10.5
Mugen MBX6 nova +4
bustedpiecesrc is offline   Reply With Quote
Old 04-05-2009, 06:38 PM   #18
Hey guys does anyone know what size the screws that hold the mount to the chassis are and where to get them?
Old 04-05-2009, 06:46 PM   #19
Trader Rating: 19 (100%+)
Look in your manual, most cars have 4mm screws that take a 3mm wrench, not shure what hardware Losi uses. I would check with WB
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 04-05-2009, 06:53 PM   #20
Its an 8-32 x 1/2 screw. Where would I get one of these?
Old 04-05-2009, 07:08 PM   #21
Integra's Avatar
http://carolinasrc.com/Webstore/Scri...idproduct=3579
Old 04-05-2009, 07:11 PM   #22
I just got them from tony's screws
Old 04-05-2009, 07:18 PM   #23
Thunder Tiger's Avatar
Thumbs up
When using loctite clean all your screws and screw holes with acetone to remove any grease, oil or old loctite then use a small amount of blue Loctite only because Red will take 450 degrees of heat to remove a cured screw. You can use Loctite primer to shorten the cure time fron 24 hours to only one hour and if the fastners are plated you will need Loctite primer to get a greater holding power than 25% of the Locitites ablity. If you can not find any loctite primer acetone will work in a pinch, just apply a drop to a screw hole prior to inserting and tightening a screw
Thunder Tiger is offline   Reply With Quote
Old 04-06-2009, 02:40 AM   #24
Well said. There is Never any need for Red loctite in this hobby.
The Working Man is offline   Reply With Quote
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Mugen MRX-4R Joe Os Nitro On-Road 1545 02-07-2011 02:55 PM
2nd cracked case.. engine mount problem. any suggestions? builtb16a Nitro Off-Road 39 08-15-2009 12:44 AM
