Old 04-04-2009, 08:18 AM   #1
Default tell me what else i need to run my car kit
I bought a mbx6, got my engine, muffler, servos and starter box.
shock oils, tires, wheels, lube, paint.
I know i need gas, radio/transimitter.
When i got the starter box it did not come with anything to actually start the car. Do i need a glo plug igniter??? Air filter oil??? what kind of batteries??? What kind of glo plugs??
I just want the damn thing running
dreaux is offline   Reply With Quote
Old 04-04-2009, 08:22 AM   #2
bump. Bout to go to the hobby shop
Old 04-04-2009, 08:24 AM   #3
tick tock.
Old 04-04-2009, 08:28 AM   #4
cary's Avatar
Trader Rating: 67 (100%+)
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-04-2009, 07:25 PM   #5
You definitely need the glow ignitor. Check the starter box and see if there are batteries in it. You could have a box that has one big battery (12v) or 2 stick packs. You will need a battery pack for the car to power the reciever and servos. Make sure you get at least a 1600mh rechargable. You will need something to charge it all too. I recommend a super brain 959 or such. This will charge most everything you have unless you are using a 12v battery in your starter box. Make sure that you charge your stuff slowly. The brain defaults to 3amp charging and you will be wailing on your hump pack. I charge at 1amp if I have the time.
Depending on the wheels you get you will probably need to get tire glue. I would get this anyway since most preglued rims/tires will peel off a little bit.
Not knowing what engine you got and if it is new or not it is hard to say what you need. But you will definitely need filter oil and depending on what setup you have I would get extra outer filters. I would get at least 2 extra glow plugs and lookup your engine and see what is recommended. If the engine is new, I would pick up a $20 heat gun to warm the engine for break in. Search the site for breakin tips.
It sounds like you got a new buggy since you needed paint, so I would also get a body reamer/scissors to get the body done. And if you are building the kit from scratch a dremmel is well worth the money.
Lastly I always have a complete set of shock shafts as backup. Nothing sucks more than you day ending because you didn't have a $5 part...
Good luck!
-Keith
killerX2 is offline   Reply With Quote
Old 04-04-2009, 07:41 PM   #6
xDaRReLLx87's Avatar
It would also be ideal to get a shock oil kit, as well as a shock spring kit. This will be crucial when racing and finding your setup. I'd also get a Camber gauge.
I'd go to Wal*Mart and get you some "3 in 1" air tool cleaner for your afterun and air filter oil. Also be sure to get a few spare parts such as A-arms and shock towers. other than that, killerX2 nailed it.
DaRReLL
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
RDLogics Mongoose KMac Nitro On-Road 2117 03-09-2011 12:57 AM
Eddie for ROAR PRESIDENT EddieO Electric On-Road 508 10-07-2008 05:13 PM
New Racer, what's absolutely necessary? noR Racing Forum 17 02-08-2008 11:24 PM
My complaint with this RC message boards, RC Magazines and RC Companies. imjonah Chat Lounge 98 08-09-2004 06:06 AM
