Old 04-03-2009, 05:48 PM   #1
junier00's Avatar
Trader Rating: 20 (100%+)
Default Needs help checking rod/crank.
Hey guys, I'm rebuilding an engine and need to know to to check that the crank and the rod are still in good condition.
How do I judge this? How much play should the rod have where it mounts to the crank?
Thanks for the help.
JR.
junier00 is offline   Reply With Quote
Old 04-03-2009, 06:47 PM   #2
chunk t's Avatar
Expect a few different answers.
-Some of us will measure the .000" of wear delta from original.
-Some of us measure concentrisity (roundness) of the crank pin
-Some of us will simply say "it feels too loose."
I like to measure concentrisity of the pin. Once you reach a differance of about 5% I consider the pin ready for replacement. Any greater than 5% and you risk pin failure.
What to look for... 1) scaring on the pins. a good pin will have a nice burnished finish. 2) gaulling of the rod bearing surface 3) cracks & or voids (missing pieces) of rod bearing surface. 4) segment of rod bushing completely worn away. **some rods do not have inset bushings, but inspection remains the same**
caviots- 1) you need a min of .0015"-.002" play between the pin & rod bushing so proper lubrication can occure. 2) the crank pins are ALWAYS under load 360-degrees of crank rotation. Trust me... you won't eat a pistion because of a loose fit. 3) as the rod and pins wear the port timings slightly change and CR gradually falls (5%-10%). So don't be surprised if you need to change nitro %, plug temp & pipe as the gallons flow through the engine.
Just because a rod and pin are loose, it does not mean they are ready for a change. This just means they are good and borken-in. The rods and pins wear together as a set, the moment you replace the crank or rod, they have to wear (cut) new bearing surfaces. This mis-match of new and old will cause the two parts to wear excessively fast until the bearing surfaces match; by this point the wear will probably be great enough the "good old part" is now a "bad old part", out of tolerance and in need of replacing.
I guess my short answer is don't replace unless you have good reason. and when you do replace... replace everything; the rod, crank and wrist pin.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
