Losi 2.0T RTR front cup and bone problem. >
Old 04-16-2011, 07:36 AM
Suspended
Default Losi 2.0T RTR front cup and bone problem.
Can't figure this out, I have had the whole front end apart, replaced the bones, cups, hinge pins, HP holders ETC. but the bone only goes into the front cup a couple MM even with 110% droop. The chassis is new as well. The arms are not rounded out at any corner either. Next step is to replace the spindle and carriers but would like some insite or a possible thread linked if you know what my problem could be please.
orijen is offline
Old 04-16-2011, 07:51 AM
Integra's Avatar
post a picture, we can tell you if its not right.
Integra is offline
Old 04-16-2011, 08:14 AM
Suspended
Yeah, the pic taker is M.I.A at the moment.
I'm telling ya, I have had this thing apart a million times and can't seem to get this one. If it lands just a bit off, something is tweeking and the bone pops out. Tha plastic is all good. It's literally in the cup about 3mm, thats it. Am I overlooking something?
Thanks man!
orijen is offline
Old 04-16-2011, 08:58 AM
Integra's Avatar
Thanks man!
Have you had it pop out on you ? How much droop Are you actually running ? We need a picture in the end.
Integra is offline
Old 04-16-2011, 10:56 AM
krash'um's Avatar
mines is the same way, it looks like it will pop out with contact but I tell you what it has never popped out yet, I have read in one of the other threads that it is a common thing but I don't recall many having problems with it popping out, its just that it doesn't go any further in. Good luck.
krash'um is offline
Old 04-16-2011, 08:00 PM
l3asher's Avatar
There has been a running change on the bones. The new one are a little over 2mm longer. I bet if you measure them yours are right around 148mm. The new ones are just a tad bit over 150mm. Call Losi, not all of the tech guys know this. This comes from Adam Drake on the Losi forum.
l3asher is offline
Old 04-16-2011, 09:23 PM
just bought a roller and had the same issue.
replaced the bones and now i can actually run the 110mm droop from the set-up sheets. before i changed the bones i could only run 105mm droop or the bone would pop out at the diff outdrive.
going to contact the distributor in Australia and see if they will supply the new ones.
menzo is offline
Old 04-17-2011, 01:41 AM
krash'um's Avatar
Nice!
krash'um is offline
Old 04-17-2011, 03:42 AM
Suspended
Thank you!
Yes at 110% they were only barely in the cups. If it was to land just a bit off they were popping out.
orijen is offline
Old 04-17-2011, 04:27 PM
asaraneta's Avatar
Appreciate if you could give us the part number so we could check on this new dogbones.
Cheers
asaraneta is offline
Old 04-17-2011, 04:37 PM
l3asher's Avatar
Cheers
Running change = same part number.
l3asher is offline
Old 04-18-2011, 12:34 AM
krash'um's Avatar
Thanks for the info, I'll consider changing mines too.
krash'um is offline
