A missing tooth on main gear
So i went to start my buggy the other day and i started it but then after about 3 seconds i hear a really high ringing sound then a crack then the engine stops So i figured my shoes were blown and a bearing blew up. My shoes were blown but my bearings were fine, and i bought new shoes and springs and put them on there. And i put the engine back on and aligned it, and just as a check, i rotated the clutch bell. It was a good mesh but then it jammed and i noticed that it jammed on a missing tooth gap on my main gear
I know i have to buy a new main gear,but would could have caused this? my bearings werent exploded when i checked my clutch bell so the clutch bell didnt come off of alignment on the crank, so what could have caused it? I dont want it to happen again!
prolly chassis flex
you wont see anything move.
does your clutch bell have any marks on the outside of it?
musta been the tooth fairy then...
happens all the time, its the chassis flexing and jamming those 2 steel gears together
you just didnt notice it last time you ran it
what kind of vehicle is this? Everyones suggestions sound on par with what probably happened. you could of fractured a tooth, and it just happened to get chunked out completely when you refired your engine for that short 3 second period.
I've seen a couple lightweight kyosho flywheels do this same thing.
and you say your shoes were blown? what do you mean, were they just severly worn? or did they actually crumble appart?
they were raised and the hole were the pin goes threw was broken on all three
