help with motor
well I just started racing again and I got a cen pro buggy and got a 4 stroke
O.S. 30 and need help with the gearing right now it is a 15t clutch bell and the car doesnt start moving till about half throttle could this be clutch setup or gearing? |
Sounds like ur clutch is way stiff.
Originally Posted by 2916jr
(Post 5631879)
Unless I am wrong the OS 30 4 stroke is a airplane engine, and I don't think it will work at all in a buggy even if you could get it mounted up and a clutch and flywheel on it, it wouldn't have enough torque to pull out!
isnt that a plane engine? :confused: they dont have the right power to run a car
haha i think he meant 2 stroke http://www.osengines.com/engines/osmg2075.html
Originally Posted by NITR04LIFE09
(Post 5632192)
lol............ Wait for him to verify if it's a 2 or 4 stroke....... |
Originally Posted by OfnaJoe
(Post 5632310)
Ain't that what I just said??
lol............ Wait for him to verify if it's a 2 or 4 stroke....... i would say deff. clutch problem gearing wont have much to do with the car not doing anything till half throttle. |
Even if he's running 1.1 springs and ultra lightweight aluminum shoes it should move at low throttle, unless something is stuck!
(Post 5632525)
Does it look like this? this is a OS 30 4 stroke!
http://www3.towerhobbies.com/cgi-bin...I=LXCNA5&P=FR# |
Not a lot of RPM to work with if it's the motor above...
(Post 5636799)
it is a 4 stroke and nothing is binding up but I am preety sure it is a clutch spring problem, the springs are 1.1's I believe, and I noticed there is a large amount of air gap between the shoes and the bell what is the gap supposed to be set at?
You really may need to do some custom clutch design to get the engagement to a reasonable rpm for that engine. Gearing is also a problem. If you had it in a truggy I would say to put buggy gears in both differentials. Not many options in a buggy though. Good luck. |
