Old 04-01-2009, 09:02 PM   #1
Default Why wont it suck?
Hi
My engine wont suck fuel from the fuel tank when I try to prime it. The fuel lines havent got any holes in them because Ive tried other fuel lines and theyre not blocked. What could it be? Any ideas welcome
Silencedsteak is offline   Reply With Quote
Old 04-01-2009, 09:04 PM   #2
Integra's Avatar
Originally Posted by Silencedsteak View Post
Hi
High speed needle is clogged....take the needle off and make sure everything is clear and no gummy fuel is preventing a prime.
Old 04-01-2009, 09:05 PM   #3
n10cities's Avatar
Default Pressure line?
What about the pressure line from the muffler? Have you checked it for leaks?
Your arrogance blinds you.....
Losi - Spektrum - Byron's Fuel - Airtronics
Robbie
GSHobby.com
n10cities is offline   Reply With Quote
Old 04-01-2009, 09:14 PM   #4
xlgraphicspro's Avatar
Maybe there's an issue with your fuel tank/lid isn't sealing right, or your tank is cracked.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 04-01-2009, 09:17 PM   #5
cary's Avatar
Trader Rating: 67 (100%+)
is there still compression no compression no sucky sucky
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-01-2009, 09:29 PM   #6
No leakes in the pressure line. Tank not cracked. needle not clogged. There is compression.
Old 04-01-2009, 09:34 PM   #7
imaxx21's Avatar
Send a message via AIM to imaxx21
how are you priming it?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 04-01-2009, 09:39 PM   #8
It works again. Just turned it over for about 40 seconds with my finger plugging the exaust and all of a sudden fuel started to go into the carborator. Thanks for all the help
Old 04-01-2009, 09:39 PM   #9
Stupid question,
Have you tried plugging the exhaust as you crank the engine over. If so there is most likely a blockage some where. Fuel filter, carb, fuel line, pressure line, etc. Also if either needle is screwed in to far it would shut off fuel flow (seen needles vibrate in, and idle screw speed vibrate out, and cause this).
John Schafer is offline   Reply With Quote
Old 04-01-2009, 09:41 PM   #10
Sometimes if the engine is very dry inside it will take a while to suck up the fuel.
Old 04-01-2009, 09:42 PM   #11
imaxx21's Avatar
40 seconds??
you've got a leak somewhere in your fuel system, should only take like 2 seconds
-Crash
Old 04-01-2009, 09:43 PM   #12
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by imaxx21 View Post
40 seconds??
+1 could be an air leak anywhere in the system.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-01-2009, 09:45 PM   #13
Tony Newland's Avatar
Trader Rating: 50 (100%+)
cap the pipe with your thumb while tapping it on the starter box... it has to push fuel at that point, unless the starter box is turning the motor backwards.
Also alot of the big starter boxes like the blue ofna one turn the motor way too fast IMO. The motor doesnt have a chance to get a good down stroke to create vacumn inside the carb venturi to draw fuel. They practically burn up the piston and sleeve without even running the engine because there's no fuel in there to lube it. I've felt engine that guys havent been able to get started on those boxes and the engine is hot.... and it hasnt even ran yet..
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 04-01-2009, 10:16 PM   #14
RJNicholson's Avatar
Take both lines off and plug the carb line with your finger. Blow in the exhaust line if you can't blow at all then your good with no leaks.
If you can pass air then listen to see if its coming from the tank since you checked the lines already to make sure you don't have a leak on the O-Ring in the fuel cap, or have a crack in the tank.
RJNicholson is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Hobby Habit Indoor - Adelaide v0rtex Australian Racing 4622 08-22-2016 04:06 AM
LI Raceway's new thread JamesSchlick Electric Off-Road 1815 10-01-2011 07:51 PM
The Official 4300 Brushless/LiPo/Foam Touring Thread FreqETag Electric On-Road 246 03-13-2007 12:10 PM
All for sale.. clinttredway R/C Items: For Sale/Trade 124 06-24-2004 12:49 AM
