Old 04-01-2009, 01:17 AM   #1
dishsoap's Avatar
Default Change Recommendations
Hi everyone.
I kinda need some adivse on what to change next on my Losi 8 B for performance. My problem is the back end. I cannot seem to get it tight and feels really loose in the back.
I am having a problem on the turns and getting it squared up to hit the straight. It seems that when going into turns the back end spins out and when coming of of turns its loose as well. I just feel like I have no grip and the buggy dose not want to plant itself to the ground as it keeps bouncing all around the place.
I cant hit the straight full power due to this.
Here is my current set up what should I try next to tame it down for more grip?
1) Shocks were just serviced with recommend weight
2) Sliver springs in the front and green in the back
3) AKA City Blocks Medium
4) Diffs front 5 middle 5 rear 2
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 04-01-2009, 01:35 AM   #2
NRGman's Avatar
go the next size up with the rear swaybar, that will help keep both rear wheels stable.
Team Associated RC8B | GOOOOO Team Associated!
<-| Team Associated RC8B | Novarossi Toro Nero 21T | DX3R | Purple Rush|->
NRGman is offline   Reply With Quote
Old 04-01-2009, 02:14 AM   #3
Try to play with the rear roll center, camber and toe angle. Good luck
cheapskate.brok is offline   Reply With Quote
Old 04-01-2009, 03:12 AM   #4
Regional Moderator
marccaracer's Avatar
Perhaps lower the rear ride height to get more weight transfer back there.
Jeff Mann
marccaracer is offline   Reply With Quote
Old 04-01-2009, 08:15 AM   #5
Increasing rear toe in will make the car plant the ass end when you get on throttle.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 04-01-2009, 08:21 AM   #6
Akhor's Avatar
I was actually going to give the opposite advice.. Remove the swaybar all together.
I was having a similar issue with my TC and removed the bar and it stuck like glue into and out of the corners.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 04-01-2009, 08:37 AM   #7
A longer rear camber link will really help stabalize the rear of the car. Moving the outer mounting position out one hole on the hub will make a big differance. For less of a change you could move the link in one hole in on the tower instead. For me that just wasn't quite enough improvement. I did try the link even longer. The car felt real good but my lap times really dropped off. So don't lengthen it too much.
John Schafer is offline   Reply With Quote
Old 04-01-2009, 08:41 AM   #8
That was one of the first things I tried on my 8B and, it didn't work very well. Running the lightest sway bar in the rear is what seems to work best.
Old 04-01-2009, 10:08 AM   #9
SPEED37's Avatar
You might try moving your rear shocks out on the tower a hole or two. Hudy setup book says " outer holes = less mid corner grip, more traction into corner and squares up better on exit."
JAMMIN X2 CRT/HOUSTON/NOVAROSSI P5XS/OFNA-053
JAMMIN X2 CR/NOVAROSSI
SPEKTRUM/DX3S
BCG INDUSTRIES= Absolutely the best paint on the planet.
TEAM TERRIBLES
SPEED37 is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45705 08-13-2017 01:43 AM
BANZAI Motors Eddie Garrison Team and Company Discussions 11666 09-09-2015 12:43 PM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
What do racers look for in a track? Victory Side Electric On-Road 40 10-09-2008 07:07 PM
GP 4600 trf_racer Electric On-Road 234 06-03-2007 11:36 PM
Northwest Championship Tour, I B RACIN Northwest Racers 1297 05-13-2007 07:11 PM
