Old 03-30-2009, 01:49 PM   #1
alexrckid's Avatar
Default losi 8ight-T 2.0 servo saver spring
why is it ill-advised to run the servo saver spring that comes on the 8T 2.0 race roller..?? too stiff..??? and, is the "recommended" replacement spring(black, i believe) the one that came on the original 8-T...(p/n losa 4407)...???
alexrckid is offline   Reply With Quote
Old 03-30-2009, 02:19 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I run the 2.0 spring with 0 problems. The problem comes from the factory settings of the saver. The 2.0 spring is stiffer so it needs to be set looser than the 1.0 spring does. Mine is set a few turns below the bottom of the tube and works perfectly. Setting it looser causes another problem however, of the nut backing off easily. You just have to make sure to loctight it pretty good. The best bet is probably the 1.0 Truggy spring.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-30-2009, 03:36 PM   #3
alexrckid's Avatar
ok....thanks...
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi 8ight 1.0 Pros/Cons Chris__RC Nitro Off-Road 39 12-04-2008 01:19 PM
