Old 03-30-2009, 12:16 PM   #1
screamin' eagle's Avatar
Default Steering Servo Question - Input Needed Please
If you've upgraded steering servos, say from a 150 oz -in servo to a 300 oz-in servo, have you noticed a difference in performance? If so, how?
I run 6 volts and I am considering changing from a Hitec 5645 (160 oz -in) to Hitec 7955 (333 oz -in). It's hard to tell while the car is on the track, but my suspicion is that the current servo is having difficult turning the steering in rough/bad condition. Centering also seems poor. It's fine with the car on the bench, but who knows what's happening on the track?
Is it worth $100 to upgrade? I have a Hyper 7 PBS buggy.
Hyper 7 PBS Converted To Brushless/MMM 2650kv
screamin' eagle is offline   Reply With Quote
Old 03-30-2009, 12:23 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
You will notice a difference in handling as the 300 OZ servo stays where you put it with your radio, and 150 OZ servo will be bouncy under the load from racing, and the tires will move..Make sure your end points are set correctly and you can also now tighten up your servo saver a tad. The difference is most certainly noticeable, and worth it..For Throttle I go more for speed than torque, but wont dip below 100 oz.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-30-2009, 12:37 PM   #3
I too agree that you will see a change in turn in and how it holds the turn. This will be more noticeable when the traction is up or your truck hits ruts and bumps. Also if the servo you are currently using is not a digital, then the holding power of the servo upgrade will also show too since there will be increase in holding power.
Jaz has you going in the right direction for the throttle/brake servo specs, speed for throttle/brake with a minimum of 100oz of torque. The speed is for throttle response, torque for you to have some braking power.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-30-2009, 02:55 PM   #4
Trader Rating: 22 (100%+)
i think the focus here shouldn't be IF there is a noticeable difference, it should be, how big is the difference and is it worth spending $100 bucks for a new servo?! especially if you are a weekend racer on an amateur level...
G
p.s. dude A has $50 million bucks and dude B has 75$ million. there is a difference but i am sure you can survive with $50 million. you know what i mean?!
assivaen is offline   Reply With Quote
Old 03-30-2009, 02:58 PM   #5
G
Point taken. Trouble with that question is that the answer is different for everyone. It may be worth it to someone and not someone else.
As far as "weekend racing" goes, my theory is that the less talent you have, the better equipment you need to make up for it.
Old 03-30-2009, 03:01 PM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
There is not only a difference in performance, there is also a difference in durability. I have the "old version" (5955) on my Truggy. Night and day difference from the weaker servos (even when I was running it in a buggy...) And I'm not having to replace servos every few months. It is worth every penny.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-30-2009, 03:28 PM   #7
i have a 5645MG in my losi 8T that i had for at least 5 years in my e-maxx. it was really abused and the servo could be theoretically replaced. it still works fine though, so i don't have to replace it, i wont...
at the same time, i understand if you want to get a better servo. look at mine, it lasted for ever. so if you get something new, you can always keep it for the next project...
G
p.s. you can get platinum servos made by rolex, it will not make you a better driver
Old 03-30-2009, 03:51 PM   #8
There is also another option, which is to pick up a used 5955 for around $50-$60. Makes the decision much easier, I think.
As far as servos making people better drivers, I'll tell you from experience flying power planes that when I switched wing servos in my 27% ship (from cheap analog to high torque digital), it was much easier to control the plane on the roll axis and definitely made me (at least *look like*) a better pilot.
Old 03-30-2009, 04:06 PM   #9
I've seen you fly, remember?!
G
Old 03-30-2009, 04:12 PM   #10
vladconnery's Avatar
Trader Rating: 35 (100%+)
I run a JR Z9100T in my Truggy thats 370oz of torque. It definately makes a difference in durability and steering ability. If you are trying to push the limits of your talent. You need equipment that allows you the ability to expand your talent or atleast attempt to. Every try to go into a power slide at full speed with a weak servo. It's impossible to straighten the wheel out in the middle of the slide. Spend the money you want regret it. It's never a mistake to spend good money on basic equipment i.e. Tires, servos, engines, clutches, radio. Things that directly correspond to the ride and the controller.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 03-30-2009, 04:13 PM   #11
JEB21's Avatar
G
And I've seen YOU drive.
8ight - GoTech .21 5 port
Kyosho RB5 - Novak 10.5
Vendetta ST - Ammo 3900
JEB21 is offline   Reply With Quote
Old 03-30-2009, 04:20 PM   #12
i agree with you, if you have the money to spend it, DO IT!
Old 03-30-2009, 04:21 PM   #13
LOL
Old 03-30-2009, 04:34 PM   #14
Mack_Mechanic's Avatar
I run Jr Z9100S and Z9100T servos in my buggy and couldn't be happier.They are alittle pricey,but it is cheaper to buy good servos once instead of buying junk servos over and over again.
Steve Arms
www.rcracebarn.net
There is no such thing as too much motor....just not enough driver!
Mack_Mechanic is offline   Reply With Quote
Old 03-30-2009, 04:38 PM   #15
Trader Rating: 19 (100%+)
I suggest you put the servo you have on your throttle and swap the 7955 to steering. You will realize sooner or later that electronics is not the place you want to save $ at. No one on here will tell you that it is either well anyone that knows what they are talking about
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-24-2015 11:28 PM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
rhonda skelton Redfox03 Nitro Off-Road 210 07-24-2009 09:15 PM
