Old 03-30-2009, 08:00 AM   #1
thenova70ss's Avatar
Trader Rating: 52 (100%+)
Default THE FREEZING TREATMENT TO GET DENTS OUT OF PIPES
Hey Guys have i read some wear that you could put water in a pipe and put it in the freezer and it would take out some of the dents is this true and how much water do you put in the pipe? I don't wont to put to much water in the pipe and split it.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 03-30-2009, 08:09 AM   #2
I does work. Fill the pipe completely and plug all openings. You can check it every 20 minutes or so after the first hour. You may find that the pipe is smooth again when frozen but once the ice starts to melt you dent will start to come back a little. That means you didn't leave it in long enough, or you need to refill and freeze it again. It depends on how large of a dent your working with also.
John Schafer is offline   Reply With Quote
Old 03-30-2009, 10:28 AM   #3
Also when you're plugging up the openings make sure you secure them tightly with zip ties. If you don't, once the water starts to freeze and expand it will pop the covers off.
Losi-Runner is offline   Reply With Quote
Old 03-30-2009, 10:31 AM   #4
mfrosty's Avatar
Trader Rating: 14 (89%+)
Just did this over the weekend on my GO 0801 pipe that had the nipple pushed in. I found that the plugs that come under the lid of Losi's shock oil is a perfect fit for the larger opening. It worked like a charm and you can't even tell that the pipe was damaged now. I actually forgot about the pipe being in the freezer and left it there for 2 days, all was fine
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 03-30-2009, 10:32 AM   #5
kevin weaver's Avatar
a good idea is to plug the ends with tissue as when it freezes it expands and plugs the gap, you just need to put a small screw in the pressure line nipple. I have done it a few times on pipes. just balance it in the freezer so it will not fall over.
horizon losi - 8ight 2.0 - novarossi 367 - novarossi 21-5kt - novarossi 21-7bt
nitrotane
kevin weaver is offline   Reply With Quote
Old 03-30-2009, 11:33 AM   #6
cdbias's Avatar
Antenna cap over the fuel line nipple, fuel bottle cap over the exhaust port, and I just shove a carb cap/cover in the large opening. Sometimes it pushes the caps off, sometimes it don't. Same results either way and I too have left mine in for over a day and it was fine. Usually only takes about 2 hrs though.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 03-30-2009, 11:46 AM   #7
lethalleigh29's Avatar
it does work my LRP pipe got t-boned badly and i had to do the freezing treatment 3 times and it came back great. good little fix.
lethalleigh29 is offline   Reply With Quote
Old 03-30-2009, 02:50 PM   #8
Gumball's Avatar
awesome tip guys!!! let me try that!
I Drive.... (or try to drive LOL!)
KYOSHO INFERNO ST-RR w/ BCE K7-RR | EB-Mods EXTECH .24 | TRINITY BIG BOY PIPE | J Concept FUTABA | ACE SERVOs | AKA | BYRON's GEN 2 30% | RB S7 (back up) | Intellect LiPo | KHZ
and
KYOSHO INFERNO GT (GymKhana RC - Project)
Gumball is offline   Reply With Quote
Old 03-30-2009, 02:58 PM   #9
madmaxx's Avatar
nice! thank's for the tip! i have a pipe to try it out on too!
YOU CAN'T HANDLE THE TRUTH!
>> http://ca.geocities.com/jleblao/ <<
^^MC carbon custom carbon fibre REVO part's!^^
madmaxx is offline   Reply With Quote
Old 03-30-2009, 09:42 PM   #10
THANKS guys i have a JP pipe i need to try this on.
CHRIS CREWS
Old 03-30-2009, 10:15 PM   #11
Trader Rating: 27 (100%+)
Ok I have a question, does a small dent in a pipe really affect performance? I ask because i put a noticeable dent in one of my pipes due to a clearance issue (its a revo). I know the exhaust flow is affected, but I guessed it would be such a negligible number it wouldn't matter. It still hauls ass, but it is a .28...
spawn_x is offline   Reply With Quote
Old 03-30-2009, 10:28 PM   #12
It really depends on where the dent is and how big it is. I wouldn't worry to much about a very small dent. If the dent is small and in the outer chamber of the pipe, it won't have much affect on preformance at all
Old 03-31-2009, 09:48 AM   #13
madmaxx's Avatar
i think any dent in a "tuned" pipe would affect it's performance seeing as it would change the exhaust pulse....
Old 05-19-2009, 01:02 AM   #14
BUMP. I dented my pipe for the first time and I'ma try this out real soon!
cheapskate.brok is offline   Reply With Quote
Old 05-19-2009, 06:46 AM   #15
RT3
RT3's Avatar
Anyone know if this would work on the Associated pipe? It has the black hard coating.
http://67.199.85.166/main/productdet...ory=4008.rc8xx
AE RC8B Black Series
AE SC10 Black Series
RT3 is offline   Reply With Quote
