Old 03-30-2009, 12:00 AM   #1
kaya's Avatar
Default how to shim the head ?
im new to nitro just got a new o.s.v-spec mod it came with one
extra shim copper and has two on the head one copper and
one silver i will be running 30% fuel do i + a shim or- one or
are thay just a gasket
kaya is offline   Reply With Quote
Old 03-30-2009, 03:16 PM   #2
kaya's Avatar
you mean to tell me that not one of you that have looked at this
post or past it up know how to shim a motor come on help me out
give me a place to start at or some thing
Old 03-30-2009, 03:18 PM   #3
pyromania's Avatar
Trader Rating: 18 (100%+)
Read the manual. If it didn't come with one, tower has the online manual.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 03-30-2009, 03:28 PM   #4
kaya's Avatar
i was hopping for a bit more than read the manual did that
thanks
Old 03-30-2009, 04:07 PM   #5
cary's Avatar
Trader Rating: 67 (100%+)
i will put two on the 0.1mm+0.2mm when i do break-in to lower
the compression a bit but will take one out when done dont
know the ins and outs of it all when to add or subtract
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 03-30-2009, 06:04 PM   #6
junier00's Avatar
Trader Rating: 20 (100%+)
You add shims when going up in the % of nitro and remove shims when lowering the % of nitro.
I don't know how many shims for what fuel though, I use the motor how ever it comes, and I've run anything from 20-30% with no trouble.
junier00 is offline   Reply With Quote
Old 03-30-2009, 08:23 PM   #7
kaya's Avatar
thanks of th help it is all new to me frist good motor nitro thing
but i will get there
Old 03-30-2009, 10:17 PM   #8
I thought you would have gotten some better repies than you did.
For the most part, yes run it as it comes out of the box. Many guys add a shim for break-in and remove it afterwards. There are many other things to consider if your looking to change the preformance of the engine using the head shims.
Shims can alter the clearance between the pistion and the bottom of the head as well as, compression, and ignition timing. It's probably best that you don't remove any shims until you learn much more about nitro engines. However adding the extra shim can help improve some charicteristics of your engine. It can tame (reduce) the power a little, reduce stress on the rod and bearings very slightly, engines seem to rev slightly higher, and get slightly better fuel milage.
There is a lot more to this topic, and before I stick my foot in my mouth, I need to quit and let an expert take over. How's that for a tease?
John Schafer is offline   Reply With Quote
Pine Hills Dirt Racing (Arana Hills Brisbane Qld) dazyz Australian Racing 9307 07-08-2017 11:56 PM
JL EVO 3 "TUNED" Team Kamikaze Onroad Nitro Engine Zone 396 07-01-2014 09:03 PM
EB MODS HEAD BUTTON Frank L Nitro Off-Road 88 07-22-2010 03:25 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Go Tech Engines pino Onroad Nitro Engine Zone 331 08-04-2009 08:39 PM
Pre-Detonation problems NEED u experts opinion!! TXRC8racer Nitro Off-Road 12 11-09-2008 08:18 AM
IDM Picco jag Onroad Nitro Engine Zone 36 03-12-2007 01:16 PM
