Old 03-29-2009, 09:15 PM   #1
mira5489's Avatar
Default how often to change bearings for buggy engine?
hi all,
recently heard from friend that periodically change engine bearing can longer the engine life. Can anyone tell me how much run time(how many gallons of nitro) i should change my engine bearings?
thanks
Mira
Team Losi Racing - Dynamite - ECX racing - Hope - Team Orion - Nitro-x - Spektrum
Taiping Track Operator : Email: sungsoonming@yahoo.com / HP: 012-5120309
mira5489 is offline   Reply With Quote
Old 03-29-2009, 09:19 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mira5489 View Post
hi all,
thanks
Mira
There is no set amount of run time, or gallons of fuel..It all depends on what fuel you run, if you use ARO how well you store your engine, how you broke it in, if you start it cold, etc, etc..The only real way to know when and if they need changing is to tear it down and check em..you will see/hear if they need to be trash
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-29-2009, 09:32 PM   #3
houston's Avatar
Trader Rating: 91 (100%+)
hi all,
thanks
Mira
you can hear the rear main when it is going out , it will sound like its rattling when it is idling . when you grab the cooling head it will stop . change them soon . byrons fuel is great for bearing longevity . i recommend rbmods full synthetic after run oil . it is the best
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
