Best clay for offroad
Well, you are kind off limited to what clay is in your area. Clay is usaully more expensive around here in TN $300.00 a load for clean rock free clay, cuz they use it for packing footer bases. Yet in some areas like GA, its cheaper cuz thats all they have. All clay is not the same, some clay is very hard, and some have a Loam in it so it is softer.
Basically, just get whatever clay is available. It does not need to be 100% clay, you can go up to 30% dirt to clay mix and have a awesome racing surface.
Thank guys,
In my area, we have a lot of mix for the clay, red, dirt for garden(ok not good for a track hehe).. dirt with sandmix, dirt with stonemix
Currently we use a light brown clay and is very difficult to make jump and is so much hard.
What type of dirt use the nitro pit track?
We use red clay with sand for our track. I do not know the exact mixture though. They even add a little lime at times to make it hard. The lime helps keep the mixture from becoming loose and loamy. They also pack it with a roller from time to time. It pretty much depends on what kind of surface everyone wants to race on. Some like a hard packed blue groove type surface and others may like more of a loose and loamy surface. It just depends on your area and the people racing on it. I would try to figure out what suits the majority of the racers in the area. They are the ones that keep the track alive or let it die.
Tire wear is another thing that you'll want to take into consideration. Sure hard packed blue groove is an awsome surface to race on, but the tires you'll need to run on something like that will wear out quickly (one race day, 2 if you're lucky), that translates into a lot of $$$$$ for just tires, and we all know they are not cheap. That's why I prefer a slightly loamy surface, it lets you run a little bigger lug, and a little harder compound. I could probably get through an entire season with 4 sets of tires at my local club track.
Thank you guys!
For now, i think we go with a mix of sand, rock and clay for our track.
But i have a question :
How you make the jump? Did you start the jump with a haystack and after you put the dirt on or you make big jump only with the dirt?
(haystack is been this :
