Old 03-29-2009, 06:56 PM   #16
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
If you use red you will strip the screws before getting them out . Do NOT use red . Make sure you clean the screws and engine mount very good , otherwise the blue lock tite you been using won`t grab . Use lock washers a recommended with blue lock tite . Red is meant for things that will never needing to be removed , which you will eventually need to remove the engine to do maintenance , clutch replacements , and eventually a new engine .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 03-29-2009, 06:57 PM   #17
Briguy's Avatar
Originally Posted by junier00 View Post
Read above... He's using blue, but it keeps coming undone.
You read above , red is meant for permanent applications which does not apply here .
Royal R/C & Hobby
Old 03-29-2009, 07:41 PM   #18
bradfox2's Avatar
if you use red or ca glue make sure you have a micro torch handy when it needs removing.
8ight-E 2.0, Tekin RX8 1350-T, 13/46, 6s zippy/neu power, fut. 4pk
bradfox2 is offline   Reply With Quote
Old 03-29-2009, 07:51 PM   #19
It seems as though something else may be to blame. A couple aplications of blue loctite and it should be doing the job fine. That is unless there is oil in the holes in the mount, or your oiling the screw before putting the loctite on. Do the screws spin right out or are they a little resistant? Maybe you got a bad bottle of loctite. Maybe you should buy a differant bottle just in case. Could the motor be hitting the chassis preventing the mounts from making contact with the chassis? Could the mounts be machined wrong so that they don't sit flat on the chassis? The threaded holes could be oversized, or the screws undersized? I think it's time to take a real close look at things.
To check the mounts, while installed on the engine, take a file and gently work it from side to side. You'll remove the anodizing from the bottom of the mounts on the high spots first. Hopefully they file off evenly across the bottom, if not then make them even. If the engine extends past the bottom of the mounts make sure there is enough room so that it will clear the chassis. Also if you can't file the mounts because the engine is in the way, remove the mounts from the engine. Mount them on the chassis and work the file on the tops of the mounts instead of the bottom. If the engine is hitting the chassis you'll find wear marks on the chassis and engine were they have been rubbing together.
Hope you can find the problem.
John Schafer is offline   Reply With Quote
Old 03-29-2009, 07:57 PM   #20
junier00's Avatar
Trader Rating: 20 (100%+)
I understand that red if for permanent applications. That's why I did not recommend anything to solve his issue. I was just pointing out that he already uses blue and keep having the screw come loose. I use blue myself on my losi 8ight and it works great for me.
junier00 is offline   Reply With Quote
Old 03-29-2009, 07:58 PM   #21
HarleyMf2's Avatar
i used to have that problem i got new screws with lock washers and new mounts + lil bit of blue loctite solved it.
Upgrade RCID
Team Hudson
HarleyMf2 is offline   Reply With Quote
Old 03-29-2009, 08:02 PM   #22
I think I will take the mounts off and thougroughly clean them and screws. then put lock washers and blue loctite on. If this doesnt work idk.
rgrassey@me.com is offline   Reply With Quote
Old 03-30-2009, 02:32 AM   #23
I think it's time to contac Tonys Screws.....
The Working Man is offline   Reply With Quote
Old 03-30-2009, 03:05 AM   #24
wallot's Avatar
i use red as blue + nordlock washers did last 10minutes of racing
to remove red simply heat it up and it can be removed easily.
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 15283 08-11-2017 03:16 PM
