Old 03-29-2009, 02:15 PM   #1
cary's Avatar
Trader Rating: 67 (100%+)
Default silicone filled cranks and after run oil ?
is it ok to run after run oil (after run oil the brand) in my motors
just got one modified and bought two motors with
silicone filled cranks have read that it may not good to use
in motors with silicone filled cranks i also run odonnells fuel
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 03-29-2009, 05:16 PM   #2
rallyebmx's Avatar
Trader Rating: 21 (100%+)
GMK advertises theirs as silicone safe.
cpaurl
rallyebmx is offline   Reply With Quote
Old 03-29-2009, 05:16 PM   #3
Ridley's Avatar
ARO is not needed when you store your car properly and use a good fuel. Odonnels is just fine, so as long as you don't leave your car in the garage or in your truck where it will see temperature deviations and condense water inside you wont ever need aro.
Ridley is offline   Reply With Quote
Old 03-29-2009, 05:26 PM   #4
I have been using GMK's After Life oil for a year and it has been awesome. I have used it in 3 or 4 different engines, and never had any problems.
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 03-29-2009, 06:34 PM   #5
Davidka's Avatar
Trader Rating: 75 (100%+)
People have had all kinds of experiences with not using ARO with certain fuels but leaving any unburnt alcohol in an engine without ARO is a big no-no. I have seen especially bad rusting with O'Donnell's (see what I mean..) and the O'Donnell's racers/reps that I race with would not recommend not using ARO with their fuel because it's designed to run well, not to be used as a preservative. Bottom line, use ARO, there's no downside to it.
As for the silicone thing, plain ol' mineral oil is fine and you can get a quart for what 2 oz. will of branded ARO will cost you.
None of my engines have the silicone so I use Prestone marine fogging oil. It's in an aerosol spray can so I zip-tie a piece of fuel tubing onto the tube and shoot it right into the carb while spinning the motor on the starter box.
Old 03-29-2009, 09:03 PM   #6
imaxx21's Avatar
Send a message via AIM to imaxx21
GMK is the only way to go
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 03-30-2009, 06:01 AM   #7
Integra's Avatar
X2.
Old 03-30-2009, 11:28 AM   #8
JayL's Avatar
general rule for filled crank:
red ARO NO GOOD
clear ARO GOOD
JayL is offline   Reply With Quote
Old 03-30-2009, 12:54 PM   #9
cdbias's Avatar
red ARO NO GOOD
clear ARO GOOD
Never heard that before. If I ever do use any after run I use Marvel Mystery Oil.
What about that new Losi blue stuff? It's clear but it's blue.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 03-31-2009, 12:54 AM   #10
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Intresting topic,
There are many reasons why one should use ARO, most are within reason and probably would hurt in doing so. I take into account where I live. I am up in the High desert of Nv. where air is thin and the humidity is very low. Most things don't seem to rust or corrode as fast as they would in a much higher Humidity climate. Helps me to decide how often to use ARO. If I run evry week, I won't ARO my motors after every run, maybe every other run. At the end of the season I do, more for winter storage. Seems to work so far.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 03-31-2009, 05:59 AM   #11
Integra's Avatar
If your storing for more then 4-5 month's i would recommend a complete tear down and store the motor in parts....assemble when you want to run again...it'll be a lot better for the motor in the end.
Old 03-31-2009, 06:26 AM   #12
rdeppen's Avatar
Yamalube engine fogging oil is safe for filled cranks. Been ususing it for awhile on my Speed motor.
More importantly is ALWAYS run the fuel out of your motor completely at the end of a days use. Burn off everything leaving only the oil residue behind is more important than using an after run oil IMO
rdeppen is offline   Reply With Quote
Old 03-31-2009, 09:30 AM   #13
JayL's Avatar
I've seen marvel eat the fill, I use it on all my non filled engines though...
Losi blue, hmmm, never seen it, I tend to stick to engine company products for engines
Old 06-07-2009, 09:59 PM   #14
Frank L's Avatar
Trader Rating: 148 (100%+)
So if I used the red hobico ARO in an OS speed 1 time did I kill it?
Old 06-07-2009, 10:02 PM   #15
imaxx21's Avatar
doubt it...
the GMK stuff is blue
-Crash
After run oil Alan D. Nitro Off-Road 7 04-22-2009 05:22 PM
After Run Oil steponit! Onroad Nitro Engine Zone 10 11-18-2007 05:04 PM
After run oil - for motors with Silicone Putty GMSchmidt Onroad Nitro Engine Zone 10 06-17-2007 02:19 PM
