Old 03-29-2009, 12:53 PM   #1
Default Engine storage
Hi
When you have finished for the day what do you do to the engine i.e afterrun fuel/or after run oil or both just would like to know as i do both but cannot get any more afterrun fuel.Rb says wash the engine internals with white spirit?But never seen this done before?
Quietman is offline   Reply With Quote
Old 03-29-2009, 12:56 PM   #2
Smile
RUN IT OUT OF FUEL THATS IT
hermsrc is offline   Reply With Quote
Old 03-29-2009, 12:56 PM   #3
Charles Godwin's Avatar
Tip fuel out of tank. Run the lines dry on the box, 20 small drops of ARO. 5 seconds turn over on the box,job done
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 03-29-2009, 01:05 PM   #4
Old 03-29-2009, 01:37 PM   #5
Originally Posted by Quietman View Post
Hi
Higher or lower quality fuels depending on fuel brand, will do different things to the metal in your motor. If your using a higher quality fuel's such as Werks or Byrons Gen 2 this schedule should be good.
If you will be running your car again within the next two days:
- Do nothing.
If you will run it within the next week:
- run the fuel out.
If you will be packing it up for longer than one week.
- Run fuel out
- Put 4 drops of after run oil in the carb, and 4 through the head button hole.
- Turn the motor over a few times by hand to get oil on the inner bearings.
If your packing your motor up for the winter:
- Run fuel out
- Put 10+ drops of after run oil in the carb, and 10+ through the head button hole.
- Turn the motor over a few times by hand and shake the oil around inside the motor, to get oil on the inner bearings and coat all surfaces.
- Seal the motor in a plastic zip lock bag
(Keep in mind it the air touching the metal surfaces is what helps create rust.)
This works very well for me, in fact I have had some motors that reach the 7-8 gallon mark before rebuilds with this method.
Other things to keep in mind:
- After run oil can ruin some glow plugs (Use an old plug to burn out the oil)
- Less expensive fuels might require after run oil immediately.
- Use carb, exhaust, fuel inlet caps to seal your motors up, and reduce air/moister exposure.
CarCrazy is offline   Reply With Quote
Old 03-29-2009, 01:52 PM   #6
cary's Avatar
Trader Rating: 67 (100%+)
what about silicone fillers in some cranks just got two motors with
filled cranks use odonnells fuel in the past have all ways used
after run oil in my v-specs (after run oil the brand) is this ok
use with silicone filled cranks
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Punggol Off-road Track. Superb Singapore R/C Racers 9453 02-24-2010 09:26 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
FS:Serpent Impulse Pro spec/w Extras ezveedub R/C Items: For Sale/Trade 10 09-30-2007 05:48 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
Hopped up TNX F/S.... mavrick0 R/C Items: For Sale/Trade 13 08-02-2006 03:27 PM
