Old 03-29-2009, 10:03 AM   #1
Jaz240's Avatar
Trader Rating: 52 (100%+)
Default Shortening Servo leads?
Do you guys think it is Ok to shorten the wires from the servo to the RX? I was wondering if it would have any ill effects, since my throttle servo is right next to my box, and has like a 10 inch wire, if I could cut and solder and get rid of 6 inches of wire this would give me lots more room in my batt box...
Whats the verdict?
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-29-2009, 10:10 AM   #2
air8's Avatar
If you feel comfortable re-working your connector to RX it isn't bad. I've done it a few times just to try it. If you mess up the connector you can buy more and they're not expensive. They basically just snap in place. If you are super careful you can work the metal tabs out of the plastic connector, cut the wire to length, then re-attach the tabs. It's easier to buy new connectors, then cut the wire and attach the new connectors.
The other way is to de-solder the leads to the servo circuit board. I wouldn't recommend this way cause you really have to be "The Man" when it comes to soldering so you don't screw up the circuit board.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-29-2009, 10:22 AM   #3
I shorten leads pretty often.I use a product from Custom Electronics that looks just like the factory terminals & connectors & their crimpers made specificly for their product.I dont think they have a web site but most any hobby shop that is heavy into planes & helis will know of them,I got mine at a hobby town.CE addy is 934 east houston ave Gilbert AZ 85234 (888)584-6285.When your done it looks factory but limits where you can use the servo.
butch man is offline   Reply With Quote
Old 03-29-2009, 10:26 AM   #4
air8's Avatar
You mean there is a set of crimpers for those connectors? Gaaahhh! I feel so robbed. How have I missed those for the last two years?
--"U Ain't Fast!!"
Chris Pearce
Old 03-29-2009, 10:37 AM   #5
Jaz240's Avatar
What I want to do is just cut out 6 inches and then splice the wires back together with a dab of solder and some heat shrink tubing...Will the splice draw the same current? Is it ok to do it this way?
Old 03-29-2009, 10:58 AM   #6
Trader Rating: 53 (100%+)
u have a pic that way we know what were looking for.....
great thread jazz ....crimpers would be awesome
Rick Hess
Tekno RC--Protek RC
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 03-29-2009, 11:14 AM   #7
Jaz240's Avatar
Anyone! I'm looking to do this today
Old 03-29-2009, 12:34 PM   #8
Jaz240's Avatar
someone?
Old 03-29-2009, 12:56 PM   #9
GregH's Avatar
Send a message via AIM to GregH
If you can solider well, then go for it. I've done it in the past without any problems.
GregH is offline   Reply With Quote
Old 03-29-2009, 01:36 PM   #10
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
http://www.servocity.com/html/servo_...rs___pins.html
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-29-2009, 01:36 PM   #11
Integra's Avatar
X2....make the solder Joint as Small as possible and DO NOT let the solder wick into the wire...it can and WILL break if you let too much solder in...also make sure you have small enough shrink...test a piece on a junk servo wire or a switch wire or something to make sure it will actually seal up the connection.
Old 03-29-2009, 01:37 PM   #12
Integra's Avatar
Originally Posted by Scott Fisher View Post
cool....thx for that Scott.
Old 03-29-2009, 02:08 PM   #13
Jaz240's Avatar
Thanks guys..I'll let you know how it turns out..
Old 03-29-2009, 06:38 PM   #14
The jaws on those crimpers in the link look like the ones I have,they have a step in them so they crimp the wire clamp & insulator clamp to different sizes good stuff.
Old 03-29-2009, 07:53 PM   #15
rdcracer's Avatar
You could go either way. Cut and splice will not have enough loss to effect anything. I also build scale planes and have to wire out to 95" wingspans and the system they recommended works great and is alot cleaner than splicing.
R & RC TIGHTWAD RACING
Where any price is too much.....
BMI 1/10 & 1/12 Copperhead
Scapel, Losi 22, Jammin SC10, Wraith
rdcracer is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Shortening servo wires TL_XXX-S_racer Electric On-Road 6 01-13-2008 10:18 AM
Servo,Speedcontrol,transponder lead shortening Darkseid Electric On-Road 12 03-17-2007 07:32 AM
Shortening servo wires Accord Electric On-Road 12 12-01-2003 12:31 AM
