Jammin' X2 Buggy
#436
I don't have the car anymore but when I did... Yeah I wanted to put 3 in the rear. I liked the way it felt with 5,5,5 but it only ran really well with the track wet. Then with that Arm adjustment the car was more predictable and recovered faster.
#437
I tried diffs 7,7,7 here in Malaysia weather very hot. I fell good and it just planted on the floor with very stable in and out all corners. Just one thing it taking bigger corner and slower down in each corner compared to before 5,5,3. Haven't got the 5k diff oil yet, when it come going to try 5,5,5 with the same setting you mentioned before.
#438
Got a couple questions regarding the X2 shocks. Are you guys using the short shockends or the long ones. And also how many mm or rod is showing between the shock body and the shock end when fully extended on front and back in mm please. Thanks.
#439
Been a while since I have seen this thread... TTT!!
#441
Shock pistons and Bumpy track setup
Hey Guys I'm from Alberta Canada and my local track is hard clay which gets pretty bumpy and the jumps get blown out.
I've tried 1.35 with 35f 25r and my car feels bouncy even at 15-20 degrees celcius? now I'm using 37.5f and 30r and it's still bouncy. But the worst part is during takeoff on the blown out jumps. The car twitches sideways off the takeoff and hard to recover.
The best I have found is silver and yellow rear springs with 1.35.
I tried 1.2 pistons but I think it's too much pack for the takeoffs, mabe lighter sway bars will help? What do you guys think?
Running 2 antisquat, 3 Rear toe, 5,5,3-5 Diffs
#442
I've ran 1.3 holes front and rear for awhile. for 15-20C weather I'd be using about 30F and about 25R. So your oil choice seems pretty good. Thats weird about your take offs. No bent shock shafts or...??
#443
5-5-3 in diffs works great but what springs are you running? blue front white rear? if the track is rough and blown out put the silver/crome one on the rear and that will help a ton.
#444
5-7-2 diffs
1.4 pistons and 32.5-35wt all around
2* antisquat
2.5 rear toe in
blue front silver rear or silver all around
b block mounting up front middle hole upper center arm mounting
middle upper hole or inner upper hole shock mounting
2.3 f 2.5 r swaybars mounted on the end (flush with ball)
#445
try this
5-7-2 diffs
2* antisquat
2.5 rear toe in
5-7-2 diffs
2* antisquat
2.5 rear toe in
#447
