Old 02-11-2010, 07:37 AM   #436
smb17's Avatar
Send a message via AIM to smb17
I don't have the car anymore but when I did... Yeah I wanted to put 3 in the rear. I liked the way it felt with 5,5,5 but it only ran really well with the track wet. Then with that Arm adjustment the car was more predictable and recovered faster.
smb17 is offline   Reply With Quote
Old 02-12-2010, 08:57 PM   #437
David_Aw's Avatar
Thumbs up
I tried diffs 7,7,7 here in Malaysia weather very hot. I fell good and it just planted on the floor with very stable in and out all corners. Just one thing it taking bigger corner and slower down in each corner compared to before 5,5,3. Haven't got the 5k diff oil yet, when it come going to try 5,5,5 with the same setting you mentioned before.
TEAM HONG NOR MALAYSIA / AE TEAM ASSOCIATED / T-WORKS RC / VP POWERMASTER FUEL / PROLINE RACING / LAP PARADISE RC RACEWAY / WWW.AWHOBBY.COM
HONG NOR X3 SABRE(V2) 1:8 SCALE PRO BUGGY WITH OS, S-POWER & NINJA .21 TURBO ENGINE
HONG NOR / JAMMIN X2-CRT 1:8 SCALE PRO TRUGGY WITH RB BXR .21 TURBO ENGINE
RACE DIRECTOR: MYLAPS RC4 DECODER & SPARC 2 SOFTWARE (H/P: +6016-7855848)
David_Aw is offline   Reply With Quote
Old 02-14-2010, 09:24 PM   #438
Trader Rating: 32 (100%+)
Got a couple questions regarding the X2 shocks. Are you guys using the short shockends or the long ones. And also how many mm or rod is showing between the shock body and the shock end when fully extended on front and back in mm please. Thanks.
mcion is offline   Reply With Quote
Old 05-20-2010, 08:44 PM   #439
RobS's Avatar
Been a while since I have seen this thread... TTT!!
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 05-20-2010, 09:12 PM   #440
jmaxey51's Avatar
do not run the long shock ends, the droop will be way off and next to impossible to set. and for shock body to shock end i always just screwed my shock ends till the top of the shock end just barely ran out of thread.
jmaxey51 is offline   Reply With Quote
Old 05-20-2010, 09:46 PM   #441
Default Shock pistons and Bumpy track setup
Hey Guys I'm from Alberta Canada and my local track is hard clay which gets pretty bumpy and the jumps get blown out.
I've tried 1.35 with 35f 25r and my car feels bouncy even at 15-20 degrees celcius? now I'm using 37.5f and 30r and it's still bouncy. But the worst part is during takeoff on the blown out jumps. The car twitches sideways off the takeoff and hard to recover.
The best I have found is silver and yellow rear springs with 1.35.
I tried 1.2 pistons but I think it's too much pack for the takeoffs, mabe lighter sway bars will help? What do you guys think?
Running 2 antisquat, 3 Rear toe, 5,5,3-5 Diffs
Uptown is offline   Reply With Quote
Old 05-20-2010, 10:17 PM   #442
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I've ran 1.3 holes front and rear for awhile. for 15-20C weather I'd be using about 30F and about 25R. So your oil choice seems pretty good. Thats weird about your take offs. No bent shock shafts or...??
cpaurl
rallyebmx is offline   Reply With Quote
Old 05-20-2010, 10:24 PM   #443
jmaxey51's Avatar
run 35 all the way around in shocks, make sure they move freely and get full travel. also make sure all of your arms droop the same. and run 1.2 pistons. the reg say bars are fine. just make sure everything is equal. i had the same problem with mine and i found out one of my shocks wasnt moving the same, the piston was warped and the other time the blatter had a hole in it. hope this helps some.
5-5-3 in diffs works great but what springs are you running? blue front white rear? if the track is rough and blown out put the silver/crome one on the rear and that will help a ton.
Old 05-20-2010, 10:27 PM   #444
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
try this
5-7-2 diffs
1.4 pistons and 32.5-35wt all around
2* antisquat
2.5 rear toe in
blue front silver rear or silver all around
b block mounting up front middle hole upper center arm mounting
middle upper hole or inner upper hole shock mounting
2.3 f 2.5 r swaybars mounted on the end (flush with ball)
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 05-20-2010, 10:36 PM   #445
jmaxey51's Avatar
Originally Posted by looper View Post
try this
5-7-2 diffs
2* antisquat
2.5 rear toe in
one question do you run the Jammin X2?? i ran that same set and that thing was like driving one ICE!! you must have some great traction tracks.
Old 05-20-2010, 11:04 PM   #446
looper's Avatar
Yeah it does like to be Lutz'd around the corners with this setup but it does grip good, mine is a x1.5
Old 05-20-2010, 11:08 PM   #447
rallyebmx's Avatar
Running 2 antisquat
Try 1 antisquat. Not for the jumping problem, just general handling
cpaurl
Old 05-20-2010, 11:30 PM   #448
jmaxey51's Avatar
yeah i it was just too loose for me, i only like 5-5-3 or 5-5-2. and i never ran anything but the 3 or 3.5 toe in and and 2 anti squat and ran the stock sway bars, but i had mine on the tight side and it worked well but switch to HB and all the aggravation was over
Old 05-21-2010, 04:44 AM   #449
looper's Avatar
Should have seen when i put the 3* block on back and ran 5-8-1 that was fun to drive. although just a wee bit twitchy 5-7-2 is my preferred diff setup
Old 05-21-2010, 08:23 AM   #450
SuperEk4's Avatar
its good to see Jammin or hong nor cars are still popular here. They are not so popular in my country anymore.
although i am racing 1/8 ep only i still prefer jammin as its very tough n not too expensive.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Jammin X2 CR beta bob Nitro Off-Road 14 08-12-2009 05:40 PM
Jammin X2 CRT Truggy hlpressley R/C Items: For Sale/Trade 20 04-14-2009 06:10 AM
