Old 10-11-2009, 09:50 PM   #391
kel_racing's Avatar
Trader Rating: 15 (100%+)
Cool
"One more secret
We made our own link type front end. After the testing it made the car turn more smoother and really improved the handling over bumbs."
GaragJ
What did you use as the stand off mount at the shock tower?
Can you post more pics of the stone guard/ 808 body mod.
Glad to see so many others are staying strong with the X2 I seem to be the only one running the buggy in my area
Kasey
KEL Racing
kel_racing is offline   Reply With Quote
Old 10-12-2009, 02:03 AM   #392
diozxlive's Avatar
Kasey
KEL Racing
is it really that old?
RC Flight/RC Grift and Drift
GP reactor, Hacker Superzomm XXL, mini funtana, mini ultrastik, bmr-2, e-hawk 1500, trex 450v2SE black, trex 450v2SE silver, Trex 500cf, trex600nsp, Thunder tiger 1/5 Ducati Desmo, revo3.3, HB cyclone ms, cyclone black, Tamiya volkswagen beetle, Mugen MBX6, X2 CRTpro
diozxlive is offline   Reply With Quote
Old 10-12-2009, 03:26 AM   #393
mc_knijver's Avatar
"One more secret
Kasey
KEL Racing
can you post a picture of your modification?
Frans van der Knijff
HotBodies D8T - Corally PHI 09 - HongNor X2-crE - HongNor SCRT
Picco - Fastlane Graphix - Ko propo - AKA Tires
mc_knijver is offline   Reply With Quote
Old 10-12-2009, 04:57 PM   #394
kel_racing's Avatar
diozxlive- alot of people around here are running the 8ight 2.0
up
mc knijver- check back on page 25 of this thread Garagej has attachments of his front link mod, power went out last night and my quote went stupid so it looks , my bad.
Kasey
KEL Racing
Old 10-14-2009, 12:35 AM   #395
mc_knijver's Avatar
NP Kasey, I'll try that mod the next race to see if I like it thanks guys ;-)
Old 10-14-2009, 02:27 AM   #396
diozxlive's Avatar
i'll be getting a kit soon, any "must have" spare parts?
Old 10-16-2009, 08:35 AM   #397
does the rear chassis brace from the x2 buggy longer than the x1x cr braces?
jeremiah23 is offline   Reply With Quote
Old 10-16-2009, 09:57 AM   #398
bigmatt's Avatar
Trader Rating: 16 (100%+)
yes, use the rear brace from the x1 crt. I bought the king headz braces front and rear. had the rear break on me. But the rear crt is a perfect fit for the x2 buggy. And the front is the same x1 buggy.
bigmatt is offline   Reply With Quote
Old 10-16-2009, 11:45 AM   #399
thanks for the info,btw i have another question coz i only own the x1xcr,is it worth converting the x1x to the x2?
been thinking of installing x2 gear diffs on my x1
Old 10-16-2009, 02:56 PM   #400
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I still run my X1 buggy for practice days and my x2 for race days. Its definitely worth switching!! They are not lying when they say 'more steering'. Its like a sharper knife
cpaurl
rallyebmx is offline   Reply With Quote
Old 10-21-2009, 06:42 PM   #401
kel_racing's Avatar
Alright slightly confusing myself, i have an X2 running with the X1 pinion and ring gears in front and rear diffs, but it has the 44t spur, running a 13t clutch bell, this is the way the buggy came when i boughtit off of a local racer, it works but not right, I have the spiral cuts but the backlash was set wrong and they are ate up (previous owner). Should i run the bigger spur off the x1 with those or just run what i got, will the bigger spur work with the chassis, or shouldi just wait till they come off back order and run my x1 completly
Kasey
KEL Racing
Old 10-25-2009, 04:35 PM   #402
kel_racing's Avatar
I went ahead and started running the X1 again and waiting on the pinions to come in at the lhs.
Old 10-25-2009, 07:40 PM   #403
Default new out of the box
just hit the track with the x2 this weekend. would have to say that is alittle better then the x1cr, but i am having problems under accelration with the car getting really lose. Setup is 5,5,2 Stock springs, 400 in front and 200 in rear. 3.0 rear block Camber -2 all the way around new rb mods go tech 7 port with the stock clutch stuff in the box. Changed rear chassis brace from alloy to plastic. This help some, however not enough. Car jumps really good and handles rough area good. Just to lose or really twitchy out of the hole. Any help would be nice. Like alot of you guys have said its hard to find jammins on the east coast so exchanging setups is out of the question.
wired is offline   Reply With Quote
Old 10-25-2009, 07:54 PM   #404
rallyebmx's Avatar
I found a little of this too. I am running the yellow springs in the rear with the shocks mounted on the inner rear shock tower holes with a 2.5 rear sway. I just tried 1k in my rear today. I was lovin it.
cpaurl
Old 10-25-2009, 08:45 PM   #405
bigmatt's Avatar
I own 5 go tec's. try changing the clutch springs to .95's rb modded engines are really powerful. I went down to the modded 3 port. It still whips the car around,just not as violently. I also use kyosho big bore shock pistons. I believe 8 hole 1.3s or 1.4's I can't remember. I will look up and post. One other thing, that is the ride height. I set mine at 30 rear/29 front. I use losi oil and after you run it for 2-3 tanks the oil will heat up and make the axle levels sag. I just raise the ride height back to the above specs. I never vary the oil front to rear by more then 5weight. Like 45frnt/40rear. Just remember everyone likes their car setup for your driving style. Just keep making little changes till your comfortable with the setup. I have blue frnt springs/white rear. I tried other combo's but that seems the best for me.
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Jammin X2 CR beta bob Nitro Off-Road 14 08-12-2009 05:40 PM
Jammin X2 CRT Truggy hlpressley R/C Items: For Sale/Trade 20 04-14-2009 06:10 AM
