Old 05-06-2009, 09:55 PM   #196
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Originally Posted by BSchorr View Post
What spring combo you guys like for the 16mm big bores?
I said 16mm bigbores....
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 05-06-2009, 09:58 PM   #197
sugs's Avatar
Naw, Ill be just as fast!
For the X1 or X2? On my X1 I liked silvers all around. For the X2, blue in front, white in back, seems to be the consensus for now.
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 05-06-2009, 10:05 PM   #198
rallyebmx's Avatar
Trader Rating: 21 (100%+)
And I'm still saying silver springs for 16mm the x1
rallyebmx is offline   Reply With Quote
Old 05-06-2009, 10:11 PM   #199
bigmatt's Avatar
Trader Rating: 16 (100%+)
thats whats on myx1x
bigmatt is offline   Reply With Quote
Old 05-06-2009, 10:19 PM   #200
bigmatt's Avatar
So basically... An X1 is just as good, just doesnt have the better shocks.. Good, I wont need to upgrade mine!
thats right, if your x1x is dialed in there is no reason for x2. I have both. I started gathering parts to build the x2 last summer. then when the conversion came out bought it and built the x2. I have a x1 that I really liked, got a good deal on it. thats why I built x2 to race. also have the hyper 8.5 and as far as I am concerned, noway will it handle as well as a jammin. just my opinion. also the x2 seems more stable all around.
Old 05-07-2009, 03:40 AM   #201
Canīt agree on that, the X2 buggy is alot faster overall, lighter, accelarates much better than X1X, i tested both the X1X and X2 and i was 1.5seg's faster on the same track with the X2.
I think the final result is much better than the X1X, IMO.
Pdpower is offline   Reply With Quote
Old 05-07-2009, 10:47 AM   #202
rangerjkb's Avatar
Trader Rating: 38 (100%+)
Send a message via MSN to rangerjkb
Good to hear about the X2 being overall faster than the X1X. Just built the conversion in Feb and looking forward to finishing, then putting it through it's paces on the track. The only area on the track that other brands were difficult to keep up with was in the corner speed department for me, sounds like it's been addressed with the new Buggy. Can't wait to retun this month and do my best to put a Jammin Buggy back into the lead pack in my local area. Much, much practice ahead and learning the new performance characteristics of the new X2B. Reading all the posts (between three forums), sounds like it's best to begin with Chad Bradleys recommended set up.
JB
rangerjkb is offline   Reply With Quote
Old 05-07-2009, 07:51 PM   #203
BSchorr's Avatar
My steering linkages bind up in the front when I suspend my car up in the air. The bind when the steering gets do about 60% of its travel. but when I set the car down and load the suspension some.. It free's up. So its to do with the tie-rod ends/balls... Do any of you run no droop and let the arms hit the chassis? or do you use the screws?
Set the chassis on the tires, and measure the droop from the table to the bottom of the c-hub?
Seem like my arms will not fall fall enough down with the screws not touching to achieve a 25mm front droop
Old 05-07-2009, 09:46 PM   #204
sugs's Avatar
BSchorr, if you look closely at the plastic ends, you will see a faint impression of a circle around the hole on one side. On the side with the circle, the hole is a little larger than the one on the other side. The larger hole goes up on the hub side of the linkage, and down on the ackerman side of the linkage.
Old 05-07-2009, 09:48 PM   #205
BSchorr's Avatar
Ya, they are.. SOmething maybe bent
Old 05-07-2009, 10:09 PM   #206
sugs's Avatar
Yeah, something must be bent or broken because I can't think of anything else that would cause that.
Old 05-07-2009, 10:12 PM   #207
BSchorr's Avatar
The hub tie rod ends are ground up some from the wheels, Im just going to start bye replacing them.
When I screw the droop screws in some to life the arm, then the steering free's up. lol
Old 05-07-2009, 11:57 PM   #208
Not a beat up sticking u-joint at the wheel is it?
butch man is offline   Reply With Quote
Old 05-08-2009, 05:34 AM   #209
BSchorr's Avatar
Naw... Its the beat up steerting tie rod ends.... I singled it out, its coming from the right side. Ill repace the tire rod ends.
Old 05-08-2009, 07:15 AM   #210
DRKWNG's Avatar
I would suggest trying Matt Gosch's setup. The shock's with the 1.2 x 6 pistions and losi 20 in front and losi 17.5 in the rear makes the car feel really stable.
Dan Walter
DRKWNG is offline   Reply With Quote
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Jammin X2 CR beta bob Nitro Off-Road 14 08-12-2009 05:40 PM
Jammin X2 CRT Truggy hlpressley R/C Items: For Sale/Trade 20 04-14-2009 06:10 AM
