Old 04-19-2009, 08:17 PM   #151
NsideLine's Avatar
Send a message via Skype™ to NsideLine
Originally Posted by Marz View Post
I've never noticed that issue my self dude.
I know its happened to me twice now, and I've only ran the car for two practice sessions and two race days... One time it happ. with the carbon tower and the other with the alum. Plus, I know it was brought up to me before I ever even got the car by Vance, who'd had it happen multiple times in his first two weeks with the car as well... Then, out of the blue, another team guy brought it up to me as well last saturday, and I saw his car sitting there with it all bent too... It struck me as a problem, because mine was still bent from Thurs. night's practice session...
Team Jammin' - www.jamminproducts.com
TRU Racing - www.tru-rc.com
OFNA - Hobao - NitroHouse - www.nitrohouse.com
TKO Comp. Development - www.tkocompetitiondev.com
NsideLine is offline   Reply With Quote
Old 04-19-2009, 08:31 PM   #152
Marz's Avatar
Very strange ... I'll be sure to take note of what's happening at our local tracks with that issue.
Marz is offline   Reply With Quote
Old 04-19-2009, 08:46 PM   #153
bigmatt's Avatar
Trader Rating: 16 (100%+)
PUT UP SOME PHOTO'S. If you can.
bigmatt is offline   Reply With Quote
Old 04-19-2009, 10:22 PM   #154
sugs's Avatar
Hmmm. Bent a couple of screws there, but never the mount itself.
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 04-20-2009, 05:13 AM   #155
NsideLine's Avatar
I'll get a few photos of the part on here later...
Old 04-20-2009, 07:04 AM   #156
Hi.
I've also bend a upper shock mount at the base, but still use that same shock mount, i think what caused it was that it wasn't properply screwed in.
Pdpower is offline   Reply With Quote
Old 04-20-2009, 08:00 AM   #157
JUD
JUD's Avatar
Man these problems with the x2 are making things difficult now. Maybe I should just keep my x1. I have no problems at all. It doesn't break.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 04-20-2009, 08:36 AM   #158
bigmatt's Avatar
I haven't had any of the problems listed here yet. I drove for the first time on a race track this week end. I was all over the place. why my car is not destroyed I'll never know. Nothing bent,broke or tore up. I would say this is on durable car. I thought for sure I would have broken the shock towers at least. I barrel rolled that thing so many times I'm still cringing thinking about it. This car is super durable.
Old 04-20-2009, 01:04 PM   #159
i run my shock mount with a washer behind the head of the screw and a washer betwen the aluminium shock mount and the carbon towers. the washer that works best is the washer that goes under the akernman plate. its the perfect size. i have never bent one and i have had mine since the worlds. i know that people had bent the mount without the washer but havn't heard of someone bending them with the steel washer between the mounts and the tower until now.
Manufacturers Cup
questions please e-mail Manufacturerscup@gmail.com don't PM (i dont ever check it)
Manufacturercup is offline   Reply With Quote
Old 04-21-2009, 05:50 AM   #160
Marz's Avatar
Hey guys, do any of you have an issue with your ride hight?
I've just re done my shock oils, and noticed that the ride hight is really high and springy, even tho my shocks are wound all the way up, and the sway bar is quite loose. The back isn't as bad, but still very confusing. I usually have the arms approximately level, but at the moment, they're nowhere near that/
Old 04-21-2009, 06:58 AM   #161
NsideLine's Avatar
Actually, there is no reason this isn't one of the most durable cars out there. It was one of the reasons I decided to drive it. Was just sick of having parts wear out and break all the time. It is well known as that. Watch a couple of guys with it, and see how often they don't finish a race due to breakage... It's kinda rare. Plus, we're just trying our hardest to come up with things that may be of concern so we can pick it apart and make it better. That's what makes it fun. I mean, comeon... a screw bending is going to determine what car you drive...? I've seen 0 issues with the rest of the car. The driveshafts last longer than the HB or losi's did for me... and upon further review, the diffs are wearing just fine. I doubt I'll need to replace any parts for quite awhile... Just concerned what would make you fear upgrading your car, now that you have an idea of where to strengthen and reinforce it to prevent any issues whatsoever... Stick to it. You'll be happy you did.
Let's see... The only other thing I have had to replace is the wheel/axle bearings as they seemed to take on dirt too quickly and got rough. They didnt blow up or freeze completely. They just got dirt inside it seems, so I switched them out for TKO ceramics. You can check them out here>>> http://tkocompetitiondev.com/product...roducts_id=155
They are fantastic. No problems since...
Oh, and by the way... I got a few sets of these clutch bearings from Peter as well, and they are absolutely fantastic. I was worried about switching back to standard sized clutch bearings, being that the HB ones are slightly larger and seemed to last a long time, and I remember having to switch them out more often with my old Kyosho and Mugen cars - But these directional 5x10x4's are worth every penny, and I've been on the same set for over a gallon now, and they have gotten smoother if anything... He said he's personally gone 3-4 gallons on a set, and then switched them out as preventative maint., but that's it! Here, check em out... http://tkocompetitiondev.com/product...roducts_id=341
Sounds about right. I have finished every qualifier, and every main, as well as every practice session on the car so far, and after 2+ gal on a brand new car, that's pretty good, I'd say...
Yeah, I am trying the dual-washers now, but hadn't in the past. I never had a problem with the washer in front like it is now. Hoping it'll fix this. I believe it will.
Hmmm... Why would you have an issue with the ride height? You're using the white springs in back and stock blue up front? Is there any binding that is taking place? Do you have the shocks built with too much pressure? I'm not sure if that's even possible with the stock bladders in them... Are they built per the manual? Try dissecting the front end first and checking each thing oone by one.
1. Free movement throughout the suspension range
2. Shock build quality - is anything binding? how far do the shock shafts come out on their own when compressed without springs on them?
3. Sway bar tightness - You left the set-screws that secure the sway bar loose enough for it to move freely in the channel, correct?
4. Post a pic of your front end completely assembled. Drop the car from 12-16 inches and then take a pic.
I'm a little baffled as to what it could be. I run the shock collars almost all the way up, but don't get the bones above level unless I adjust them down a ways... Lets see what you are talking about...
Old 04-21-2009, 08:12 AM   #162
bigmatt's Avatar
Thumbs up
nsideline, well said!
Old 04-21-2009, 08:23 AM   #163
joeling's Avatar
Some pics of X1's & X2's in action at my local track over weekend :
HN X2 CR OS Speed WC Ti, HN X1 CR Polyquest 5S Neu 1512 2000kv MMM
HN X2 Neu 1515 2000KV Polyquest 5S 6000mah MMM, HN X2 OS Speed WC
Hyper 9e Medusa 2000KV 4S 6000mah MMM, Hyper mini STe Medusa 3300KV 3S 2500mah MM
Savage FLM ext. 5S MMM 8XL, E REVO Medusa 1600KV 6S MMM
Thunder Tiger ST Neu 1515 2000KV Lutach esc 5S 4800mah
joeling is offline   Reply With Quote
Old 04-21-2009, 08:31 AM   #164
JUD
JUD's Avatar
I will consider the x2 later. Don't get me wrong I know the car is durable. But it seems to be some bugs that need to be worked out.
JUD
Old 04-21-2009, 09:09 AM   #165
sugs's Avatar
My ride height was a little high when I first switched to the X2, but the springs settled in during the first race day. Only thing I can think of that would throw it way out of whack is if you are using the long plastic ends instead of the short ones all the way around.
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Jammin X2 CR beta bob Nitro Off-Road 14 08-12-2009 05:40 PM
Jammin X2 CRT Truggy hlpressley R/C Items: For Sale/Trade 20 04-14-2009 06:10 AM
