Old 03-28-2009, 08:39 PM   #1
beginner4life's Avatar
Trader Rating: 9 (91%+)
Default I have a manifold from a OFNA pipe, would it work with a JP-2?
I have the manifold from a OFNA pipe, would it work with a jammin JP-2?
beginner4life is offline   Reply With Quote
Old 03-28-2009, 10:02 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
Only if its a one piece manifold...not if its a manifold that requires a rubber coupler
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-29-2009, 09:13 AM   #3
It is a one piece manifold. It is from a OFNA PCR pipe. here is the pipe but the stinger is broken so i will just use the manifold and use http://cgi.ebay.com/ws/eBayISAPI.dll...=tab%3DBidding
Old 03-29-2009, 09:35 AM   #4
Jaz240's Avatar
Yes that combo will work just fine, you may need to to use a different size gasket (that's the purple rubber piece shown in the photo)
Old 03-29-2009, 10:09 AM   #5
Thanks, i have the gasket from the PCR so i should have the right one.
Old 03-29-2009, 02:04 PM   #6
The stinger got bent against the pipe and tore on one side but was still half on. I bent it back and it looks good as new, could i put sealant around the connection point and use it?
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
Old 03-29-2009, 02:10 PM   #7
Jaz240's Avatar
Solder it up, so there are no doubts
Old 03-29-2009, 05:04 PM   #8
solder? wouldn't i have to weld it?
*Team Terribles*
