Old 04-03-2009, 04:04 PM   #76
kaya's Avatar
can some one tell me which way the oil hole on the speed rod
faces to front or to the back of the motor or does it matter
kaya is offline   Reply With Quote
Old 04-03-2009, 04:08 PM   #77
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Oil hole faces the front of the motor away from the backplate. The reason it matters is that the lower bushing is tapered on the crank side.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 04-03-2009, 04:19 PM   #78
kaya's Avatar
thanks i can see that now that you ponted it out will do
Old 04-05-2009, 08:15 AM   #79
Originally Posted by JAMMINKRAZY View Post
There is nothing cheaper in quality about the ninja at all. Infact, quite the opposite. The ninja uses better parts than the OS branded engines do. For instance the use of the .28 block, solves the cracking case problems. The crankshaft is the same quality as the speed, just designed without the tungsten weights to provide a different power band. The con rod is identical to the speed. The carb is the same (21J), and the piston/sleeve are the same quality, just in a 5 port design. The ninja is IMO and in the opinion of many others, the best v-spec ever made. The speed is a great engine, but for the price I would rather have the ninja. I guess it all depends on how you look at it. If you want the super smooth powerband of the speed, there is nothing that can replace that, but the ninja is every bit as good as the speed(quality wise).
i guess i dont know anything about the engines....
bbmods is offline   Reply With Quote
Old 04-05-2009, 08:18 AM   #80
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
LOL maybe they don't realize who/what you do? Oh well, I trust your opinion.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 04-06-2009, 04:33 AM   #81
patrick lsp's Avatar
Trader Rating: 170 (100%+)
Default pinch?
in general how much fuel thru a new p/s/r/ b4 it actually breaks in and stops getting stuck.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Old 04-08-2009, 05:02 AM   #82
anybody? 6 pages on this thread, i know someone can shed a little lite on the pinch.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
Old 04-08-2009, 09:41 AM   #83
Plain and simple, OS motors don't have the pinch that others do. That is partly why they run so well. They don't have all of that excess pinch to get rid of before they start to make power. If it still has good compression with a plug in, run the hell out of it. My findings are that OS engines loose most of thier pinch fast, but retain enough to have very good compression for the life of the engine.
-Koby Kubrin-
Old 04-08-2009, 09:52 AM   #84
cary's Avatar
Trader Rating: 67 (100%+)
this is what i to have found after a gal or so i have 3 os all the same thing
good but not overly tight pinch but fast as a scolded cat
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 04-08-2009, 12:03 PM   #85
my speed has about 4 gallons through it and when cold has good pinch but when it warms up it loses most of it ,makes me worry a little about life expectancy but runs good and cool
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 05-07-2009, 05:54 PM   #86
Trader Rating: 32 (100%+)
well I just picked up a used speed with 1 gal through it, to use in my future buggy... lol.. haven't even bought a buggy but bought speed because of all the raves on the normal vspec.
and if I have to rebuild in 5 gal's (probably won't since i tend to run rich and and 20%) tower has p/s/r speed comb for 169. which price of a half decent motor anyways.
devilchrist is offline   Reply With Quote
Old 05-08-2009, 10:03 AM   #87
JayL's Avatar
very nice!
you may want to replace the rod now and you will be set for a long while
JayL is offline   Reply With Quote
Old 09-10-2009, 11:06 AM   #88
lucky2's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to lucky2
Default os speed
my first speed went thirteen gallons mag head before it lost compression, put new psl and bearings back up motor now , this speed in my car is at nine gallons and still cant turn it over buy hand the life of this motor is crazy good. both the nova and os seem to run well but havent seen life exp of nova yet.
XrayXB9 os speed19, futaba Bls servos, 4pk, my own deep pocket, FIORONI USA, tamiya trf417, tekin, futaba bls, Rc hobbies ft lauderdale
lucky2 is offline   Reply With Quote
Old 09-10-2009, 11:28 AM   #89
I run OS I have one that has 12 gallons on it and still runs. Now not saying it runs at the top of its game but it still runs. I pit at 11 minutes and can go for 12 1/2. its plenty of power and holds a tune great. I also have to the Toro and I PERSONALLY dont like it. to much power when I dont need it and not enough where I do. That is my opinion. I know a guy that will only run that engine period. Both are good, just what do you prefer
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-18-2009, 01:43 PM   #90
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Speed Ebay
Punch in OS Speed EBAY with shipping 336.00 2 left
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
