Old 03-26-2009, 11:35 PM   #1
vti-chris's Avatar
Default Has anyone tried this break-in method?
http://www.rbproducts.com/cgi-bin/ub.../t/000237.html
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 03-27-2009, 01:08 AM   #2
mfrosty's Avatar
Trader Rating: 14 (89%+)
Sounds like a very sound theory. I'll have to try it when I rebuild my 5 port GO
~TQ Racing~O.S. Engines~AKA~Answer R/C~
http://www.youtube.com/user/frostyone1977
mfrosty is offline   Reply With Quote
Old 03-27-2009, 06:38 AM   #3
Mikme-63's Avatar
Thats ALOT! of work
Mikme-63 is offline   Reply With Quote
Old 03-27-2009, 12:04 PM   #4
it's how I broke my C6 L2g in. Seemed to work just fine.
Cvdiver is offline   Reply With Quote
Old 03-27-2009, 12:07 PM   #5
r1harper's Avatar
Trader Rating: 24 (100%+)
when i break them in on a stand...i use Rody's team method. has worked real well for me.
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 03-27-2009, 12:15 PM   #6
cary's Avatar
Trader Rating: 67 (100%+)
i will be going out to the garage right now and will
give it a try
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 03-27-2009, 12:44 PM   #7
t8rtot's Avatar
Trader Rating: 14 (94%+)
Appears to make sense.. i have a new Picco 3R that i will be tryin this method on
Sfida
t8rtot is offline   Reply With Quote
Old 03-27-2009, 03:17 PM   #8
houston's Avatar
Trader Rating: 91 (100%+)
all i can say is that if you try and start your engine cold you aren't doing it right
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-27-2009, 04:58 PM   #9
+1
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 03-27-2009, 06:13 PM   #10
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Originally Posted by Jesse View Post
+1
+2
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 03-27-2009, 06:32 PM   #11
houston's Avatar
i tell my guys after heat cycling (using a heat gun before firing up everytime)to run the engine for at least 6 tanks straight . same thing effectively but .......................just a lil diff.
Old 03-27-2009, 06:37 PM   #12
pballer2777's Avatar
Trader Rating: 27 (100%+)
let me ask this after u run the 6tanks or gal which ever u perfer. is the breakin complete or do u still have to drive a few tanks b4 tuning it.
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 03-27-2009, 06:44 PM   #13
houston's Avatar
run in is complete when the engine drops temp instantly and gains power , usually happens within one or two laps while running on track . sometimes after 2 gallons NEVER START COLD!!!!!!!
Old 03-27-2009, 07:02 PM   #14
smittyusmc's Avatar
That sound like a great idea. But I use the flood method it works great, it sound kind of crazy but it works great my friend at the track has been doing it for a long time a his motors run great. All you do is put your car on the starter box a fire up and then slowly richin the high speed and give it gas at the same time until it is wide open a the tires are barly spinning.
Do that for 6 tanks keep it running the intired time after 6 tanks keep it running and lean in an hour at a time until shes at a good temp and go racing.
smittyusmc is offline   Reply With Quote
Old 03-27-2009, 07:08 PM   #15
Smittyusmc - That method is brutal on the con rod. Have seen four motors ruined that way (from on-road days.) Do not do it. WAY too much stress on the rod.
toolmbx6 is offline   Reply With Quote
