Old 03-27-2009, 07:21 PM   #16
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by toolmbx6 View Post
Smittyusmc - That method is brutal on the con rod. Have seen four motors ruined that way (from on-road days.) Do not do it. WAY too much stress on the rod.
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-27-2009, 07:32 PM   #17
t8rtot's Avatar
Trader Rating: 14 (94%+)
how'd it go cary?
Sfida
t8rtot is offline   Reply With Quote
Old 03-27-2009, 07:33 PM   #18
Trader Rating: 93 (100%+)
Default Break in
I have used this break in method on 2 on road motors and it's the best by far that I've found . I made a fixture that will hold a gallon jug upside down and used a clunk out of a boat fuel tank with a brass tube goin to the top of the jug. When the motor gets fully broke in it will all of a sudden start revving up. I run a zenon that I broke in this way and have about 4 gallons on the original rod and still heat it every start or it sticks at tdc. If you use this method and do it right you will have a faster longer lasting engine.
latemodel13 is offline   Reply With Quote
Old 03-27-2009, 07:55 PM   #19
Frank L's Avatar
Trader Rating: 148 (100%+)
I use the heat cycle method as on johnnycoolguy.com only difference is the first 20-25 min I heat cycle at idle on the box then drive at varried throttle positions not more than 1/2 throttle. After the reccomended time I slowly race tune and engines last into the 8+ gal range.
Old 03-27-2009, 11:06 PM   #20
cary's Avatar
Trader Rating: 67 (100%+)
just got done it took some time like 9hrs but worked out grate a
little messy with all the oil on the floor piston and rod look just fine
sleeve has pinch at tdc i think this method of break-in works out
just fine will put new rod and pin my o.s.v-spec full mods is set
to go
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 03-28-2009, 12:07 AM   #21
vti-chris's Avatar
Let us know hoe it turns out to be on cold pinch after a few more tanks.
OS are known for low pinch after a gallon or so.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 03-28-2009, 06:20 AM   #22
All i ever do is heat to 200 with a heat gun, start and wrap the head in foil to keep the temps up. I run about 6 tanks through it in a row. I do not heat cycle or anything. After that, I tune and let her rip.
My engines always make insane power and run for many gallons. I have GRP's ifthat matters to anyone.
antman450 is offline   Reply With Quote
Old 03-28-2009, 06:24 AM   #23
smittyusmc's Avatar
I have use this method twice and both seem to work great so far but I will keep that in mind thanks for the advice.
smittyusmc is offline   Reply With Quote
Old 03-28-2009, 07:15 AM   #24
cary's Avatar
good pinch with out sticking at tdc going to track to day
i will see
Old 03-28-2009, 09:41 PM   #25
t8rtot's Avatar
how did it go?
Sfida
Old 03-30-2009, 12:47 AM   #26
cary's Avatar
it is all good put a race tune on it fast as hell still has good
pinch cold used a heat gun on start up run 5 tanks (125cc)
i think all and all it whent good think i will do it on next one
Old 03-30-2009, 12:55 AM   #27
kaya's Avatar
this break-in method sounds like a good way to go
kaya is offline   Reply With Quote
Old 03-30-2009, 02:30 AM   #28
Trader Rating: 36 (100%+)
9 hrs?
I like what I'm reading...but think I'll stick to my normal routine. I don't believe my neighbors would be very happy with a constant 9 hr bee like drone :P
NitroOB4You is offline   Reply With Quote
Old 03-30-2009, 09:49 AM   #29
cary's Avatar
run at idle in the garage with the door open i could not hear it in the house
so i know the neighbors cant hear it dogs and kids make more noise playing
Old 03-30-2009, 11:38 AM   #30
lethalleigh29's Avatar
i have a very similar run in method but i leave mine in the car and have it idle for 4 litres of fuel without stopping it takes a full day so i usally do it at my mates workshop at least i can keep him company while this process carry's on i havent had a motor fail on me yet.
lethalleigh29 is offline   Reply With Quote
