Old 03-26-2009, 02:24 PM   #1
farny21's Avatar
Trader Rating: 22 (96%+)
Default temp problem
i have a super tiger .27 and i havent broke it in yet and the temps are above 350 and the high speed needle is out 4 1/2 turns and running 15% nitro. help!!!!!!!!!!
farny21 is offline   Reply With Quote
Old 03-26-2009, 02:30 PM   #2
yeaklet4's Avatar
Trader Rating: 34 (97%+)
hopefully that motor is not toast already
yeaklet4 is offline   Reply With Quote
Old 03-26-2009, 02:35 PM   #3
farny21's Avatar
Not toast, still has compression. Caught it in time, make a pass, check temp, etc...
Old 03-26-2009, 02:58 PM   #4
scwrod's Avatar
Not sure what engine that is but 15% on a .27 does not sound right and may explain your heat. bump to 30% and see what happens. Hope it is still OK.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 03-26-2009, 03:05 PM   #5
farny21's Avatar
was running 20% and the same problem. so the lower the nitro the hotter. and were do you put gasket sealent at on the engine, the back plate and the carb?
Old 03-26-2009, 03:09 PM   #6
Gixxer2k4's Avatar
Send a message via AIM to Gixxer2k4
sounds like low speed needle setting
Mini 8ight
Gixxer2k4 is offline   Reply With Quote
Old 03-26-2009, 03:33 PM   #7
cary's Avatar
Trader Rating: 67 (100%+)
check the lsn this is the one on the throttle slide shoud be like
6 1/2 truns out hsn 2 3/4 out shoud be in the ball park
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
What do you guys think of this Werk's .21 Engine? Garet Jax Nitro Off-Road 82 07-20-2016 04:40 AM
calling all FUTABA 3PK users..... JayBee Radio and Electronics 1312 01-25-2015 07:57 AM
Newby Engine Temp Question isthisnameinuse Rookie Zone 9 07-29-2007 12:53 AM
Temp guns... again D_o_S Nitro Off-Road 26 07-25-2007 12:15 PM
Bore vs Stroke vs Displacement rmdhawaii Onroad Nitro Engine Zone 163 11-07-2006 12:07 PM
Engines leans down a lot once tank gets to 1/4 full WeatherB Onroad Nitro Engine Zone 25 03-09-2006 04:56 PM
Temp Gun? topslop1 Nitro On-Road 72 08-23-2003 06:21 PM
