Old 03-25-2009, 10:32 AM   #1
Hitman Racing 1's Avatar
Default 8 rtr w/ mach 427, removing roto start for bump start
Hey guys, just needed to know if there is a way to change the backplate on the 427 so I can put a normal motor mount on it and use a bump start. The motor stock is sitting on a really tall mount to give the roto start back plate clearance. Any help is appreciated.
Sponsors: Wife & Daughter!
Hitman Racing 1 is offline   Reply With Quote
Old 03-25-2009, 10:35 AM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Sure is. Its called the sportwerks pull start eliminator backplate. It is a direct bolt on to the mach. It even has a ring machined into it so you don't have to cut the starter pin off of the crank. Just bolt it on, get yourself some kit motor monts and you should be bump start ready.
http://www.amainhobbies.com/product_...oducts_id/4331
http://www.amainhobbies.com/product_...oducts_id/9001
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-25-2009, 10:38 AM   #3
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
yeah what jammin said...
anyone know how many rpms you loose with a roto/bump start on your motor creating drag?
Alex
hound_dogs_01 is offline   Reply With Quote
Old 03-25-2009, 10:39 AM   #4
out of everything ive had so far the bump start has been the easiest... if i could put one on my savage i think i would...
Alex
Old 03-25-2009, 10:41 AM   #5
Thanks homie, everyone I have asked is like theres no way unless you cut the pin off the back. I didn't really want to do that. Thanks a TON
Old 03-25-2009, 10:42 AM   #6
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I ran that eliminator plate on my Sportwerks .26 V2 (same motor essentially... great motors by the way!) Best $12 you can spend. You'll need "regular" motor mounts though if your sit too high... and of course a starter box and battery.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 03-25-2009, 10:50 AM   #7
Yeah I already baught the starter box and battery, thats how I found out about the issue with the fly wheel being to high to use the bump! It reall sucks being at the track trying to find the whole for the roto start!!!
Old 03-25-2009, 11:10 AM   #8
8ightisenough's Avatar
I changed my backplate in 5 min on my losi 8 rtr with the P/S Eliminator Back Plate part # SWK8057 and while i was at it since i needed to change motor mounts to lower the motor i went to the King Headz Team Losi 8ight/8ight-T Extended EZ Change Motor Mount part # KHZ-KP-215 which makes it a snap to remove motor to inspect clutch bearings etc...
8ightisenough is offline   Reply With Quote
