Old 03-24-2009, 09:03 PM   #1
Angry SWAY BARS
I put a set of Tekno sway bars on my slayer and the brake rod with the adjuster hit the sway bar mount can't let off brake all the way it binds up any suggestions
laser_cart is offline   Reply With Quote
Old 03-25-2009, 02:40 PM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
Trim/shorten up the brake linkage so the adjuster is moved closer to the pull eyelet.
Or find a smaller adjuster barrel/knob.
You can shorten the rod and put a new z-bend or just a bend and a collar on the end of it to retain it in the servo horn. Or if they have enough threads on the end; just dremel a bit off that end, no bending req'd.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 03-25-2009, 04:02 PM   #3
Smile
Thanks i took today and swapped around the servo horn and that helped a lot but i will cut some off with dremel thanks
BMI Racing Discussions protc3 Team and Company Discussions 10674 02-05-2017 06:24 PM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
sway bars? Kings Kid Nitro Off-Road 13 11-19-2007 05:57 PM
