Old 03-28-2009, 08:34 PM   #46
Originally Posted by beginner4life View Post
I am using Byrons Gen 2 20%, about to break in a new RB s3IIg i hear that it is hard to keep temps up, should iput a sock on the head?
It's more than likely best that you put the stock head on. I normally wouldn't use a aftermarket cooling head that is intended to lower temps while breaking in a motor. When I ran RB's a while back, you really had to get the head temps up in the 200's so that the sleeve would expand enough to not cause additional wear to the crank pin. I had seen a RB WS7 with a ruined crank possibly because the motor wasn't hot enough and put additional strain on the internals of the motor. It was egg shaped, which happened to my C5 eventually after many gallons of fuel. I hope you didn't start the break in process yet.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-28-2009, 08:46 PM   #47
beginner4life's Avatar
Trader Rating: 9 (91%+)
haha no i was saying put a sock(like you wear on ur feet) over the head to keep the temps up. I am going to use a blow dryer to get the temps up as much as i can before i start it up for the first time.
beginner4life is offline   Reply With Quote
Old 03-28-2009, 09:07 PM   #48
I can't wait to do the mad scientist thing. Very cool. I have a few ideas I'd like to try. Now I need the Mad Scintist or Witch's Brew lables. I think green would be a good color for my own "Swamp Water" blend.
Originally Posted by torco race fuel View Post
Ok john I will,
Torco will be offering a "blend your own Kit" the kit will consist of 99.9% Nitro, 99.98% Methanol,Oils and a Mixture calculator so that you will be able to make your own nitro fuel the way you or your motor wants it, this kit will be available very soon, I will post it here first for you guys if interested..
thnaks
Steven Davis
Torco Race Fuels
John Schafer is offline   Reply With Quote
Old 03-28-2009, 09:28 PM   #49
BH
Looking forward to speaking with you more Steven.
BH is offline   Reply With Quote
Nitro On-Road Addict sa RC Manila Racers 12522 12-27-2015 05:51 PM
RC news at Kuching evoton Malaysian R/C Racers 827 11-05-2013 09:37 AM
Food for Thought - Cheaper to run Thopper Electric Off-Road 38 12-22-2008 07:52 PM
GS CUP Malaysia 2008 jets Malaysian R/C Racers 328 07-08-2008 08:40 AM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
Losi LST or Traxxas Revo INVIZAGOD Monster Trucks 216 06-09-2005 07:03 AM
Wanted- Hpi Nitro Any Kind Post Here! dizboihuy R/C Items: Wanted to Buy 6 03-21-2003 05:30 AM
