Old 03-24-2009, 08:34 AM   #1
Default Engine thorough cleaning tips!
Hi, I've got an old engine that's totally gunked and clogged up... I managed to free it up and strip it, but whats the best way to clean it ? I've heard you can soak everything in petrol/gasoline/nitro and then use green wool?
whats your 'best' suggestion?
Thanks!
edwin
elty19 is offline   Reply With Quote
Old 03-24-2009, 08:42 AM   #2
reggie l.'s Avatar
get some good bearing lube...take the bearings out...spray nitro clean or brake clean trough the motor and bearings and clean it with a rag etc..lube it and put it together
_ClockWork-Racing_
http://www.clockworkracingengines.com/
~8t 2.0
~MUGGIFIED Lst-xxl
reggie l. is offline   Reply With Quote
Old 03-24-2009, 08:48 AM   #3
Default nitro clean or brake clean?
what are these? sorry if I sound like im living on the moon!
Old 03-24-2009, 11:59 AM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
They are cans of compressed cleaners..Nitro Blast can be found at any Hobby shop, Brake cleaners are at the Auto parts shop..Brake cleaner is cheeper, make sure you buy Non- Chlorinated!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-24-2009, 08:31 PM   #5
chunk t's Avatar
You may have read about it on other threds, but cooking the engine parts in a crock pot with anti-freeze will cook off the heaviest gunk without hurting the anodizing on the aluminum parts. If the gunk isn't too heavy I'd say strip off all rubber & plasic parts and soak the metal parts in citrus degreaser over night. Citrus is really agressive and will eat through a variety of greases & grimes.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 03-25-2009, 04:30 AM   #6
Default thanks!
man.. my gunk must be real bad... (coz water got in and I let it hand out there) I cooked in it antifreeze... and managed to free it, but the gunk is still there... a few nights before... I soaked it overnight in citrus degreaser... but its still there!! soaking in nitro now.. would that work?
Old 03-25-2009, 04:53 AM   #7
Trader Rating: 93 (100%+)
Default Engine
I have did this before and used paint thinner. It will clean it quick. I then clean it with dishsoap and warm water. blow it off with compressed air and lube it with castor oil. This will work very well unless you see any rust or pits in the bearings.
latemodel13 is offline   Reply With Quote
Old 03-25-2009, 07:51 AM   #8
Default thanks!
I definitely see pits!! sigh... guess thats not good!!
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 07:35 PM
