Old 03-23-2009, 08:09 PM   #1
Default When heating a new engine, what position should the piston be?
Hey guys,
Just wanted your opinions on breaking in a new engine. When heating it with a hair dryer or heat gun, should the piston be at BDC? Does it make a difference?
Chad22 is offline   Reply With Quote
Old 03-23-2009, 08:11 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
yes
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 03-23-2009, 08:28 PM   #3
cary's Avatar
Trader Rating: 67 (100%+)
when breaking in a new engine allways put the piston at BDC
i do it all the time old or new when you shut it off put the piston BDC
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 03-23-2009, 08:34 PM   #4
+1 on the bdc while heating the engine. The only time I wouldn't want the piston bdc is if you were taking off the back plate. Keep in the practice of moving your piston to bdc whenever possible to avoid forgetting to do and ruining a motor after you left the piston at the top after a run. Always check after you run. It's a routine you need to follow, one for breaking in, the other for taking the motor apart since they are the opposites.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-23-2009, 10:04 PM   #5
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
BDC...........ALWAYS...........FOREVER
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 03-24-2009, 05:00 AM   #6
Do i need to put it a bdc after everyrun even after its broken in?
cassidy is offline   Reply With Quote
Old 03-24-2009, 05:38 AM   #7
GregH's Avatar
Send a message via AIM to GregH
YES always make sure the piston is down. Just roll the flywheel until it's easy and floats.
GregH is offline   Reply With Quote
Old 03-24-2009, 07:26 AM   #8
Bigedmond's Avatar
Trader Rating: 18 (100%+)
if its not running, it should be at BDC. Rule of thumb
Bigedmond is offline   Reply With Quote
lower c-rod play helivaguy Onroad Nitro Engine Zone 6 03-24-2009 04:02 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
NovaMax lawndoggie Onroad Nitro Engine Zone 264 09-21-2004 12:17 PM
