engine bearings >
engine bearings
engine bearings
Old 03-23-2009, 10:53 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
Default engine bearings
i have some tko coming for my vspec. im just making sure i will be doing this right. i put it in the oven at what degrees and how long. and just take it out and poke the bearings out then put them back in but i gotta hurry right. i dont wanna get the grp bearing puller or anything because i dont have that kind of money to spend
losi_racer is offline
Old 03-23-2009, 11:01 PM
imaxx21's Avatar
350 for 10min, put the new bearings in the freezer
use an oven mit, fold up a towel and lay it on the counter..
take the block out of the oven and smack it on the towel, the rear bearing should fall out, if it doesnt put it back in for a few more minutes
you can use a wooden dowl or something similar to push out the front bearing.
put the new front bearing in first, then take the new rear bearing and put in the crank shaft and slide it in the block
i normally throw a flywheel on real quick and tighten it down to make sure the rear bearing is seated fully
hope this helps
imaxx21 is offline
Old 03-23-2009, 11:07 PM
cary's Avatar
Trader Rating: 67 (100%+)
there is a good vid on youtube take a look at it it help me
just did my v-specs same bearings truned out good
cary is offline
Old 03-23-2009, 11:09 PM
losi_racer's Avatar
do u have a link
Old 03-23-2009, 11:23 PM
cary's Avatar
look in how to change model airplane engine baerings
cary is offline
