Old 03-22-2009, 07:51 PM   #1
RGraves's Avatar
Trader Rating: 37 (100%+)
Default 8ight 1.0 into a 8ight 2.0??
I have a 1.0 but would like to have it updated to a 2.0, what all would it take to do this. What are the big differences? Thanks for the help
-It is more blessed to give than to receive. ~Acts 20:35
-Spec Amsoil, Jerry Welchel or Fabtech Slash
-Team Losi 8ight E- Castle Creations Mamba Monster 2650
RGraves is offline   Reply With Quote
Old 03-22-2009, 07:56 PM   #2
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
from what i understand the 2.0 chassis is 14mm longer and the shock towers are different are the 2 major differences i believe... its not worth converting... 14mm longer isnt going to make you a better driver in my opinion...
Alex
hound_dogs_01 is offline   Reply With Quote
Old 03-22-2009, 08:04 PM   #3
SLIM6971's Avatar
Trader Rating: 24 (100%+)
A friend of mine has converted his including the active diffs for about 350. Chassis is different shock towers are dimensionaly the same just lighter. A arms are different they are wider needs new cv shafts. Frt hubs are different. Radio tray is stiffer. Other odds and ends. I would have to say those are the major changes. There are alot of little things as well. He just compared the 2 manuals together and ordered what was different. Chris
SLIM6971 is offline   Reply With Quote
Old 03-22-2009, 08:14 PM   #4
so basically its $350 bucks to upgrade..... imo it isnt worth it...
Alex
Old 03-22-2009, 08:19 PM   #5
pballer2777's Avatar
Trader Rating: 27 (100%+)
drive a 2.0 and u will c how worthy it is
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 03-22-2009, 08:41 PM   #6
imaxx21's Avatar
Send a message via AIM to imaxx21
2.0 drives like an entirely different car, it handles much better than the the first one
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 03-22-2009, 09:27 PM   #7
bradfox2's Avatar
parts can be had on ebay for ~200 bucks more or less
major ones are chassis, steering assembly, front hubs and steering cranks, and center driveshafts. shock towers are the same dimensions, some ppl run 1.0 in front bc it is sturdier.
8ight-E 2.0, Tekin RX8 1350-T, 13/46, 6s zippy/neu power, fut. 4pk
bradfox2 is offline   Reply With Quote
Old 03-22-2009, 09:44 PM   #8
air8's Avatar
Alex
Whoa!! Whoa!! Be more specific and only if you KNOW please. don't just post something for no reason bud.
The Truggy 2.0 is 14mm longer. The Buggy 2.0 is only 2mm longer.
It's probaly best to go to Losi's site instead of 10 different people trying to explain the differences and the upgrades/changes to you.
http://losi.com/
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 03-22-2009, 10:39 PM   #9
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Just did my buggy,
What you need are the chassis, radio tray, throttle linkage, and rear drive line. I think it comes out to be around 150, unless you find some good deals on the parts you need.
I used all the old 1.0 buggy parts. I did mod a couple of things, the throttle side chassis guard and the rear drive line.
I cut out a little on the chassis guard to fit the throttle servo in the 2.0 radio tray. Took all of 5 minutes to do.
Rear drive line I used was an axle drive line, as the LHS didn't have a 2.0 rear drive line. I saved a little money on that, but you need the CVD condom or something like it to keep the pin in when using the axle line as there is no set screw to hold the pin in.
Other than that, not much else needed to do the conversion. You do need the little chassis screws for the droop stops. I used some AE screws I had. I noticed the difference in half a lap on the track. Just doing the basic conversion is worth it.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
Getting started:Tip's,Trick's,Newbie's come here! xsxracing Rookie Zone 59 01-03-2009 09:57 PM
