Old 03-22-2009, 07:09 AM   #1
Default 4 Cycling-2 Stroke
When 4 cycling occurs in a 2-stroke nitro engine, how should you systematically determine what is causing the problem?
I had this happen yesterday, and we eventually corrected the problem, but several of us had trouble determining what to adjust.
It would occur when we came off of full throttle. I thought it was the low speed needle, the others thought that it was the high speed setting.
Any help would be appreciated.
tk1931 is offline   Reply With Quote
Old 03-22-2009, 07:32 AM   #2
Davidka's Avatar
Trader Rating: 75 (100%+)
4-stroking is caused by a too-rich setting dumping more fuel into the engine than it can burn so it sputters. Try leaning the main (high speed) needle.
Old 03-22-2009, 03:04 PM   #3
+1, adjust the main needle first, then you may also need to make a small adjustment to the low speed needle next then the idle position last.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-23-2009, 07:14 PM   #4
Thanks for the info.
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1633 08-16-2017 11:17 AM
Cyrul's Break in Procedures revzalot Onroad Nitro Engine Zone 156 03-21-2012 02:47 PM
