Old 03-21-2009, 05:11 PM   #1
cary's Avatar
Trader Rating: 67 (100%+)
Default O.S. 21VZ-BV SPEC ROD QUESTION
was thinking of putting the rod out of a o.s. speed v-spec #osm23755020
in to my o.s. 21vz-bv spec stock rod #osm23755000 will it work ??
it is time for a new rod the speed one looks nice put will it work
cary is offline   Reply With Quote
Old 03-21-2009, 07:27 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Yup you can use the speed rod in the normal v-spec. Can't go the other way around(v-spec rod in speed) but speed rod in v-spec works just fine and is a good upgrade if you ask me.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-22-2009, 12:38 AM   #3
ehames005's Avatar
Trader Rating: 74 (100%+)
+1
Thank you to my 2017 supporters:
Sworkz--Amainhobbies.com---ProTek Rc---Huston's Engine Service
ehames005 is offline   Reply With Quote
Old 03-22-2009, 02:43 AM   #4
Yup, you will get additional oil through the conrod in addition to the oil from the standard crank.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-23-2009, 12:22 PM   #5
cary's Avatar
thanks for the info just got a e-mail from engine support hobbieco aka
o.s. engines comfirming this going to put the speed rods into both of my
v-specs have full mods tko bearings on both mod work done my
Rick at RB mods the rods will be a nice addition
now i will be a fast lawn dart thanks guys
