Old 03-23-2009, 04:40 PM   #31
Default re
if the bearings are bad this will affect the mesh yes you should be able to tell if the bearings are weak with a small screwdriver pry the cup up and down that the center driveshaft is in if there is upand down movement then the bearings are shot
toofless is offline   Reply With Quote
Old 03-23-2009, 07:52 PM   #32
Another tip for your next race is to find out how long you can run on one tank of gas. This will be helpful on determining when to pull in to pit....so bring a stop watch.
tfa8rva is offline   Reply With Quote
Old 03-23-2009, 08:35 PM   #33
ok good advice, also bruce, I took my center diff out and inspected the bearings. They seemed good but very dirty so I cleaned them and lubed them up and also put some new oil in my diff and the play seems to have gone away. Cant wait for my new bell to get here so I can get her back together!
rgrassey@me.com is offline   Reply With Quote
Old 03-23-2009, 08:49 PM   #34
One more thing for a new racer: The most important result doesn't come on a sheet of paper or through an PA system at the end of the race. It comes from taking what happened during the race day from the time you started to prep till the when you were done marshalling and learning from it. As a new racer, your learning curve is very steep, but if you look at how you raced, and what you did well in addition to what could be improved, I'm sure the next time you go out and race you'll have even more fun and possibly improved results. Sometimes, you can have a bad day and still finish decent, where as you could race your but off, and run a good race by your standards and still lose by alot. Don't measure your success off the final sheets, but by your standards and see if you are able to push to be faster, having a car that's more reliable, and having a good time. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Cyrul's Break in Procedures revzalot Onroad Nitro Engine Zone 156 03-21-2012 02:47 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
Enlighten me about tx cranky Australian Racing 15 08-17-2007 02:05 AM
Radio Question- What is best, 3pk etc.. Ryan41 Nitro On-Road 53 06-01-2007 11:30 PM
2005 hobbytown schedule ammdrew Minnesota and North/South Dakota Racing 16 04-04-2006 01:47 PM
