Old 03-22-2009, 06:16 AM   #16
t4usee's Avatar
Do everything Mr. Connery just said but also get yourself a piston locking tool. This tool will stop the motor from turning so you can properly tighten the flywheel nut. Dynomite has a tuning screw driver that has one in the handle of the driver. If your motor is a turbo type head this one will not work and you will have to get the one for those.
t4usee is offline   Reply With Quote
Old 03-22-2009, 08:17 AM   #17
JUD
JUD's Avatar
I also agree!! You have to use a small amount of locktite on that screw, or else you will loose it. Sometimes I have a problem getting my flywheel off from cranking it down soo tight. With my last engine I put a small amount of black grease around the collet so the flywheel will come off a little easier. I think that is my only part of maintenance I dont look forward to.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
D&M Speedway Topeka Outdoor Off-Road JPMSRacing Kansas/Missouri Racing 5448 10-09-2010 09:01 AM
LITTLE HELP !!!! with my losi 8ight 2.0 shaun0_18 Nitro Off-Road 54 07-09-2009 06:50 AM
