Old 03-20-2009, 12:34 PM   #16
1) Go back to the stock Losi throttle linkage and all accessories.
2) Get a high quality servo if you are using inferior servos. ( JR 9001S or Futaba 9351)
3) Make sure to not let the spring on the linkage comletely bottom out.
4) Cut as much excess linkage off behind the outside collet, so the linkage does not hit the body.
5) Set your epa's so you do not have too much throw on the throttle side or brake side. You can pull the brakes too hard along with bottoming the spring out. Only use as much brake as you need to slow the car in a controlled manor.
Travis Dupree is offline   Reply With Quote
Old 03-21-2009, 06:37 AM   #17
TTR:EB4's Avatar
i also noticed the servo felt quite hot, and the engine was only idling, and it was getting at a fairly high temp too, so would the heat from engine get to the servo? its like right next to it, or through the chassis, the servo last around 15 - 20mins of use (racing) before this happened, i was only running in a motor
and the servo was a Hitec 625MG
the receiver felt warm too, but the steering was fine
Battery - 1200 venom 6v hump pack
DX3.0 - pro receiver
so its my linkage?
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 03-21-2009, 08:16 AM   #18
I'm loving this thread.
I have been running a Hobbico CS-64 servo for throttle for a year and a half with no isssues in my 8ight 1.0. To say this servo is cheap is an understatement. $21 or so. My linkage is set up properly. I run no throttle return spring, and the rear of my radio tray is quite loose.
John Schafer is offline   Reply With Quote
Old 03-21-2009, 11:25 AM   #19
GregH's Avatar
Send a message via AIM to GregH
All this just to run a Losi.
GregH is offline   Reply With Quote
Old 03-21-2009, 11:52 AM   #20
pyromania's Avatar
Trader Rating: 18 (100%+)
Originally Posted by j_blaze14 View Post
+1, low-tech servos burn up sitting in a drawer by themselves. try running with no brake spring and just use 3 small hair rubberbands around the carb, and NO rear tray screw.
You are completly right. I hate those servos and will never touch one again. Buy the Losi Throttle Linkage. Set it up correctly and you will never have a problem again. Here is the part from A Main:http://www.amainhobbies.com/product_...ducts_id/30452
pyromania is offline   Reply With Quote
Old 03-21-2009, 11:55 AM   #21
pyromania's Avatar
so its my linkage?
I would kind of blame it on the linkage also. Use the right linkage and set up the throttle right and you will never have a problem.
Old 03-21-2009, 12:00 PM   #22
GregH's Avatar
Or you can order it here for less!
http://www.tiltedrc.com/product_info...ducts_id=20089
Old 03-21-2009, 12:38 PM   #23
jpz_67's Avatar
Trader Rating: 56 (100%+)
I dont know if I would consider hitec "inferior" . I know several losi guys in my region that switched to hitec servos for there trucks and buggies because that was the only thing that would stay alive for them. I see drivers beat the snot out of there vehicles all the time that have hitec servos and the servo still survives.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 03-21-2009, 12:46 PM   #24
HarleyMf2's Avatar
what battery are you running???????????
Upgrade RCID
Team Hudson
HarleyMf2 is offline   Reply With Quote
Old 03-21-2009, 12:48 PM   #25
Jaz240's Avatar
Trader Rating: 52 (100%+)
Hitec's are anything but inferior! I would say Hitec and JR servo's are the two best out there..at any price..I bought my first non RTR servo 6 years ago, and it was a Hitec and it just crapped out 3 months ago! $45 for 6 years of service....Give me Hitec everytime!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-21-2009, 01:01 PM   #26
jpz_67's Avatar
I am a pretty loyal Futaba user myself but after countless times of seeing a hitec srevo just being pounded on and still holding up I am giving a set of 7955's a try.
Old 03-21-2009, 05:30 PM   #27
TTR:EB4's Avatar
Venom 1200 6v hump pack
The Masher! >.<
Old 03-21-2009, 05:31 PM   #28
TTR:EB4's Avatar
thanks for all the replies guys, im going to buy a losi linkage and start from there, but i need to put a cheapee in there for this weekend (racing this weekend)
so
8b 2.0 radiotray
8b 2.0 throttle linkage
The Masher! >.<
Old 03-21-2009, 06:26 PM   #29
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
A good servo for low price is the hitec hs-985, I highly recommend the king headz servo stiffner brace, it made a huge difference, as soon as i bolted it in i could see a difference..
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 03-21-2009, 06:48 PM   #30
Integra's Avatar
the 2.0 tray is a MUCH better option then trying to stiffen up the 1.0 tray....you will have to modify the dirt guard and possible the chassis to use it tho.
Losi Constant Velocity Drive (LCD) vs MIP CVD John Stranahan Electric On-Road 263 01-24-2010 11:51 AM
TEAM LOSI MALAYSIA : the resurrection spencer Malaysian R/C Racers 161 08-08-2008 04:45 AM
Team Losi Distributor Services Sucks airsky Singapore R/C Racers 41 08-08-2007 05:59 AM
FOR SALE - all for sale posts here Sil80 Australian Racing 10483 12-29-2005 03:37 PM
TRADE!! Awesome Deal!!! lem2 R/C Items: For Sale/Trade 6 09-20-2005 07:25 AM
