Old 03-19-2009, 09:27 PM   #1
AMEZCUA's Avatar
Default O.S. V-Spec II 08/09 vs Novarossi Toro Nero .21 Turbo
Hi I am looking for a new engine to my Mugen MBX-6, I am between these two engines:
NOVAROSSI TORO NERO .21 TURBO BUGGY:
O.S. 21VZ-B V-SPEC II WORLD EDITION:
WICH ONE IS THE BEST PERFOMANCE ENGINE AND THE BEST CHOICE?
THANKS
KYOSHO MP9 TKI2,OS SPEED KO-PROPO
LOSI 8IGHT-T, GRP.28,TUNED FLEX CHASIS, SPEKTRUM
AMEZCUA is offline   Reply With Quote
Old 03-19-2009, 09:56 PM   #2
Poppin Fresh's Avatar
Toro Nero will be too much on your MBX6 which if light as a feather. If money is no problem then the OS would be your choice. I am not a fan of OS since I had two VSPEC engines blow up. I would suggest looking into the Novarossi Plus 21-4.
"Nothin says luvin like fresh baked muffins, woohoo!"
Cruizin With R/C, RCBZ, Xray, Hudy, Novarossi USA, Futaba, Avid RC
Poppin Fresh is offline   Reply With Quote
Old 03-19-2009, 10:21 PM   #3
jpz_67's Avatar
Trader Rating: 56 (100%+)
If it were me I would be looking at a plus 4 if a novarossi is what you seek. I have an mbx6 and I run a plus 4 with a 9901 and a medium nova header. It makes good, smooth usable power and gets very good runtime.
I have had several os motors and cannot really complain to much. They have a "LOT" of bottom end, get really good fuel mileage , and much like the nova are super reliable. My only gripes on an os is I have a little harder time controlling all of the power they make down low, and I just dont get the life out of an os like I do a novarossi. I have a p5 in my buggy that has over 10 gallons on it, yes its a little tired but it just keeps on going. The best I have ever seen out of my vspecs is about 8-9 gallons. But of course the new vspecII should be an even better motor with the hardened crank, I never had any bearing or crank case issues out of all my vspecs. Really a tough choice, I would have to say price would play a role in that decision but I still bet the nova will last longer.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 03-19-2009, 10:40 PM   #4
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Just get a JX Ninja will look nice in the Mooogen
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 03-20-2009, 01:35 AM   #5
The speed motor is a good motor with ceramic bearing, smooth power band, and realiable use. The draw backs are increased maintenance to ensure long engine life, and costs. I use the Speed Vspec and to me it's a good choice, but expensive. I just check the rear bearing more often and am ready to change it a little more frequently than some of the other motors I use. With the Novarossi motors, you get longer motor life, and a little cheaper in price which allows you to use the money else where. It's a matter of choice and what you are willing to do. If you have the time and tools to change bearings in a motor, then the Speed wouldn't be bad at all, but if you don't really want to do that kind of maintenance, then get the novarossi instead. Either way, you really wont be doing anything wrong as far as performance. Good luck.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 03-20-2009, 06:04 AM   #6
Mr. Twister's Avatar
Just a thought www.protwistermods.com PTM Race Prep JX .21 you can ask Mr. Novarossi "Pete Worth" how this motor is, he ran it in his mugen and loves it.
The plus 4 is is very good in buggy, i like the ofna 053 better than the 9901, helps wake the topend up on this engine.
The Toro is a pissed of engine, it would be alot of motor for buggy, but for high bite tracks, may work, Look for a Full test review in next month's RC magazines. Bess has been also testing the motor for some time now.
But a good pick would be a JX for the money or the Plus, good luck
Brian Carey
615-838-5373
Tennessee Oval Performance
Check us out on Facebook
Mr. Twister is offline   Reply With Quote
Old 03-20-2009, 06:12 AM   #7
Trader Rating: 163 (100%+)
out of the 2 engines you have picked go with the speed it is alot smoother
cjm1126 is offline   Reply With Quote
Old 03-20-2009, 11:45 AM   #8
GH Racing's Avatar
I would go with the OS
GH Racing by Golden Horizons. Buy Direct At: WWW.GHHOBBY.COM
FOLLOW US ON TWITTER NOW: twitter.com/GH_Racing
High Quality Machined Aluminum Parts and Accessories. Vancouver, Canada.
GH Racing is offline   Reply With Quote
Old 03-20-2009, 04:53 PM   #9
houston's Avatar
Trader Rating: 91 (100%+)
plus4 buggy toro nero in the truck
you will be happy
the 21-7fms is an engine that should be considered also , its a monster
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-20-2009, 07:09 PM   #10
I would say get the OS speed Vspec II. It is very smooth, and it has very stong bottom also.
silverM3 is offline   Reply With Quote
Old 03-20-2009, 07:24 PM   #11
r1harper's Avatar
Trader Rating: 24 (100%+)
i can concure with that.
TEAM AKA-RCAMERICA- Novarossi, Fusion Motorsports, W.E.D Custom Paint-Byron's Fuel - Blue Groove
JESUS SAVES, WESLEY
r1harper is offline   Reply With Quote
Old 03-22-2009, 05:26 PM   #12
AMEZCUA's Avatar
THANKS FOR ALL YOUR COMENTS I GET THE O.S.
HERE MY MBX-6 WHITH MY OLD NOVA +4
O.S. V-Spec II 08/09 vs Novarossi Toro Nero .21 Turbo-mbx61.jpg
Old 03-22-2009, 05:29 PM   #13
AMEZCUA's Avatar
AND HERE IS THE MBX-6 WHITH THE O.S. READY FOR THE NEXT WEEKEND
O.S. V-Spec II 08/09 vs Novarossi Toro Nero .21 Turbo-mbx62.jpg
